Home > Technical > Speed Pulse Wiring
M4RKUS
United Kingdom 2005 Range Rover Sport TDV6 SE Bonatti Grey
not yet! Im a bit scared of cutting the wrong wire! lol
Post #223376 Fri Apr 24 2009 2:02pm
Whistle
Post #223377 Fri Apr 24 2009 2:42pm
mobile fidelity
Australia
Using a DMM you can find the VSS at the ABS module under the bonnet. It's a Dark Green wire, but be warned, there are a few in the loom and you will need to test which is the VSS with the DMM.
Post #224117 Sun May 03 2009 12:59am
DTR
Australia 2008 Range Rover Sport TDV8 HSE Atacama Sand
Some sellers of CAN bus demux
http://www.bridgwater-electronics.co.uk/p_...erface.php
http://www.soundlabsgroup.com.au/p/CANBUS-...+Interface
There are others as I did my research about a year ago, just do a search on the net.
Presumably they come with diagrams if not I am fairly certain that somewhere on the site there is info on the CAN bus runs.
Post #224188 Mon May 04 2009 1:26pm
