![]() | Home > General > Supercharger Fuel Consumption |
dukes Member Since: 09 Sep 2008 Location: the sticks Posts: 55 ![]() ![]() ![]() |
i just averaged 17.1mpg 1600 miles to south of france and back, normally i get 15-16....i do boot it, ive always put 98 ron in which helps a bit, i just fitted overfinch exhaust system and K&n which also helps, in my view the grin factor is worth the extra dosh! dont worry enjoy it |
Loewe Member Since: 25 Mar 2009 Location: Vancouver Posts: 6 ![]() ![]() |
Does the car eat alot? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 184 ![]() |
OK, lets test you ![]() what Series was a 1973 88" LR ? what was the HP of the Petrol Engine?? what was the CC??? and how many bearings did it have??? ![]() |
Another SW Member Since: 14 Mar 2009 Location: N Bucks Posts: 180 ![]() ![]() |
OK, perhaps I should have said 'recent' LR product knowledge (i.e post-BMW)
Ok SW, almost there but your forgiven |
Bob Member Since: 19 Aug 2006 Location: Pump No. 3 Usually! Posts: 49 ![]() ![]() |
I've had my Supercharged RRS for 3 years now, and the average fuel consumption over that period (35,000 miles) is 19.2mpg, but I do tend to do a lot of motorway miles (stuck nose to tail at 70-80mph), where I get just over 20mpg. If I don't drive it on the motorway, I get c.17mpg.
Cheers Bob,
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 ![]() ![]() |
A litre of diesel contains more energy than a litre of petrol, IIRC. Hence the better mpg figures, in general. Been a long time since I was at school though, so could be wrong, lol. |
Interestingly, if I use cruise control (which I don't very often), I always get worse fuel consumption than when I use my right foot!
Bob, exactly the same happens to me with a diesel - I think its due to the engine management constantly applying the brakes on downward hills and opening the throttle hard on hills to maintain speed (instead of feathering it) |
That makes a lot of sense. Going downhill, the car slows far quicker than if you were just coasting, so it must be applying the brakes. What you would normally do is use the speed going downhill to carry you up the other side. The car brakes downhill, then accelerates uphill (sometimes changing down a gear or two). What I find particularly frustrating is when on Adaptive CC, as you come up behind a lorry on the motorway, the car slows down (as it's supposed to), but when you pull out to overtake, the car can change down 2 gears to quickly get back to the set speed. If you were doing it yourself you would judge it better, and keep it in top gear. That's why I don't use CC very often. Bob. |
You will do if you leave it in 'D' as it keeps changing gear up hills to maintain speed (and to speed up again every time a slower car has reduced your speed via ACC), so I use Command Shift and stick it in 6th gear to avoid that. Still can't better 13 mpg overall average though. |
OMG - Accelerate / brake.......that's all you need to know in the Supercharger, right??.......
