Home > Technical > SAT NAV |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 |
under one of the front seats
Thu Mar 12 2009 7:43pm |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 |
Under passenger seat, it is behind the palstic panel at the front, needs a bloody good tug to remove the panel, if you sush the seat all way forward you will see the unit under the seat for reference |
Thu Mar 12 2009 7:52pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
You can also reach it from behind the seat without removing that front panel, just move the seat all the way forward and up, then you should be able to slide your hand above the DVD drive and "feel" your way to the lock slider and eject button. |
Thu Mar 12 2009 9:50pm |
