Home > Technical > SAT NAV
dekyd
Scotland 2007 Range Rover Sport Supercharged Java Black
SAT NAV
Rolling with laughter
EVERYBODY MUST KNOW WHERE THE SAT NAV DISC GOES EXCEPT ME
HHEEEEEEEEEELP! rrs 4.2 s-charge
rrv classic 3.9
merc slk 230 kompressor
Post #216770 Thu Mar 12 2009 6:52pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
under one of the front seats
RTFM!!
Smile
Post #216807 Thu Mar 12 2009 7:43pm
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Under passenger seat, it is behind the palstic panel at the front, needs a bloody good tug to remove the panel, if you sush the seat all way forward you will see the unit under the seat for reference Thumbs Up
Post #216811 Thu Mar 12 2009 7:52pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
You can also reach it from behind the seat without removing that front panel, just move the seat all the way forward and up, then you should be able to slide your hand above the DVD drive and "feel" your way to the lock slider and eject button.
Post #216830 Thu Mar 12 2009 9:50pm
