![]() | Home > Technical > Reverse Dip Mirrors |
RichardC Member Since: 17 Nov 2008 Location: London Posts: 6 ![]() ![]() ![]() |
I have the same problem and have discovered that by pressing the seat memory button (ie 1,2 or 3) it restores the mirrors. They'll dip again! |
Mintleaf Member Since: 18 Aug 2008 Location: London Posts: 77 ![]() ![]() ![]() |
Cheers Mate...will give it a try tonight.. RR Sport TDV6 HSE 07MY Java Black |
Misery Member Since: 07 Dec 2005 Location: Waiting for L405 Posts: 2555 ![]() ![]() |
Still an ongoing problem for me and now no more warrant ran out yesterday. |
Frozen of Wiltshire Member Since: 08 Jan 2009 Location: Wiltshire Posts: 66 ![]() ![]() ![]() |
Had the same myself when I first turned on mirror dip. I sorted it by (I think) doing the following things. Turned mirror dip on through the normal options setting process. Turned car off and locked, got back in and turned on again. Adjusted mirrors to maximum extent left/right/up/down each side, then set them back to where I wanted them. Memory programmed seat/mirror settings. Turn off and on again. All tickety boo since - they dip and return to normal when I go into and out of reverse perfectly. Range Rover Sport TDV8 HSE, Buckingham Blue with Ebony Black
