Home > Technical > Reverse Dip Mirrors
Mintleaf
Reverse Dip Mirrors
I was having a play with the reverse dip mirror setting, the mirrors go up and not down - i know it has worked in the past; has anyone seen this problem before?
Cheers RR Sport TDV6 HSE 07MY Java Black
Post #215296 Thu Mar 05 2009 11:27am
RichardC
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
I have the same problem and have discovered that by pressing the seat memory button (ie 1,2 or 3) it restores the mirrors. They'll dip again!
Post #215317 Thu Mar 05 2009 12:44pm
Mintleaf
Cheers Mate...will give it a try tonight.. RR Sport TDV6 HSE 07MY Java Black
Post #215320 Thu Mar 05 2009 1:01pm
Misery
Still an ongoing problem for me and now no more warrant ran out yesterday. Big Cry Big Cry Big Cry
Post #215328 Thu Mar 05 2009 1:28pm
Frozen of Wiltshire
United Kingdom 2007 Range Rover Sport TDV8 HSE Buckingham Blue
Had the same myself when I first turned on mirror dip. I sorted it by (I think) doing the following things. Turned mirror dip on through the normal options setting process. Turned car off and locked, got back in and turned on again. Adjusted mirrors to maximum extent left/right/up/down each side, then set them back to where I wanted them. Memory programmed seat/mirror settings. Turn off and on again. All tickety boo since - they dip and return to normal when I go into and out of reverse perfectly. Range Rover Sport TDV8 HSE, Buckingham Blue with Ebony Black
Defender 90 TD5, Tonga Green
Post #215447 Thu Mar 05 2009 6:46pm
