You are currently viewing RRSPORT.CO.UK as a guest - Register to take part or Log In
Home > Technical > Sat Nav that can't make it's mind up
jampot
Having just returned from having the RRS serviced and a few warranty items fixed, we still have an issue with the Satnav screen. The screen flashes light/dark when its dusk or on a dim day. The L/Rover garage originally informed my wife on our previous visit that it due to the lights being on auto? Having put up with the problem a little longer, ive asked them to review the Satnav again as it happens when the lights are on side/dipped or auto. This time i've been told its because the light sensor (located in the front windscreen?) is getting confused which is due to the tinted windows in the rear of the car. Not happy with the answers i was given i questioned the engineer, who informed me there was a note on the L/Rover website - not that i can find it. Logically, i feel it has to be linked to a dodgy light sensor?? - Has anyone else experienced this and if so what was the cause? Ta
Wed Feb 25 2009 7:19pm
umbertob
FWIW, the light sensor for the touchscreen is inside the instrument cluster, next to the flashing alarm LED. So, it all depends on how much ambient light hits that sensor inside the cluster, day or night. I have the factory tinted windows on the rear and don't have any problems - although at dusk the monitor can indeed seem a bit "confused" as to which brightness level to go sometimes (as the sensor reacts to the changing light level on the cluster while I drive), but it only lasts a while and it doesn't bother me. It could be a bad or partially dislocated sensor on yours. Try covering the sensor with your finger when it's bright outside. After a second or two the display should go dim - and stay dim. If the display flickers between high and low light or doesn't dim at all, you have a problem.
BTW, if you turn on the driver's side map light (at least here on LH drive cars, not sure if it's the same effect on RH drives), the monitor goes full bright, whether day or night... I think that light must catch the sensor just at the right angle.
Wed Feb 25 2009 7:37pm
baxc
mine does the same jampot only seems to do it on a bright day just thought it was the sensor reacting with the changing light
Wed Feb 25 2009 8:21pm
dazsear
Is there a way to force the satnav to think its daytime........its just mine never alters from the normal daytime setting and is a little bright at night.
Would be nice for it to alter at night but not found the change setting
Daz2017 4.4 Autobiography FFRR - love this car
Gone - VW T5 Transporter
Long gone - 2009 Disco
Long gone but never out of my thoughts - 2008 TDV8 HST
Wed Feb 25 2009 11:36pm
Adeyb
Daz
same here, I dont think mine changes at night [SOLD!]2008 TDV6 HSE - Stornoway with Ebony leather, 20" Overfinch Supersport Titanium
2008 Nissan Navara Aventura
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
