Home > Technical > Sat Nav that can't make it's mind up |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
FWIW, the light sensor for the touchscreen is inside the instrument cluster, next to the flashing alarm LED. So, it all depends on how much ambient light hits that sensor inside the cluster, day or night. I have the factory tinted windows on the rear and don't have any problems - although at dusk the monitor can indeed seem a bit "confused" as to which brightness level to go sometimes (as the sensor reacts to the changing light level on the cluster while I drive), but it only lasts a while and it doesn't bother me. It could be a bad or partially dislocated sensor on yours. Try covering the sensor with your finger when it's bright outside. After a second or two the display should go dim - and stay dim. If the display flickers between high and low light or doesn't dim at all, you have a problem.
Wed Feb 25 2009 7:37pm |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 |
mine does the same jampot only seems to do it on a bright day just thought it was the sensor reacting with the changing light |
Wed Feb 25 2009 8:21pm |
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 |
Is there a way to force the satnav to think its daytime........its just mine never alters from the normal daytime setting and is a little bright at night.
Wed Feb 25 2009 11:36pm |
Adeyb Member Since: 21 Jan 2009 Location: Knutsford, Cheshire Posts: 67 |
same here, I dont think mine changes at night [SOLD!]2008 TDV6 HSE - Stornoway with Ebony leather, 20" Overfinch Supersport Titanium 2008 Nissan Navara Aventura |
Thu Feb 26 2009 9:34am |
