![]() | Home > General > V6 or V8 |
TDV8 - it is by far the better car. 2005 Zambezi TDV6 - Gone but not forgotten
Theo_Pental Member Since: 10 Aug 2008 Location: Notts Posts: 113 ![]() ![]() ![]() |
Real men drive V8's |
Yep has to be the TDv8 if you want permagrin 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
kirium225 Member Since: 21 Feb 2009 Location: england Posts: 6 ![]() |
Go on then do tell...what difference is there between the two....is there that much difference in power. |
Chalk and cheese..........bit like the TDV8 vs. "The daddy" S/C, but more so |
Perrys Member Since: 02 Oct 2008 Location: United Kingdom Posts: 96 ![]() ![]() |
I ran a Sc for a while, I much prefer the TDV8, whilst the initial pick up of the SC is much better it does not have the mid range torque of the TDV8.
mercuryl Member Since: 07 Oct 2008 Location: Sussex Posts: 195 ![]() ![]() ![]() |
Get a V6 - performance is fine. You'll do 25% more mpg.
Believe me the TDv8 is better - on here Josh, Smarticus,VA and myself have run TDv6's since launch until fairly recently. There is nothing wrong with the TDv6, it's far better than the 3litre BMW straight 6 that was in the big Rangie, for smoothness and quietness. The Tdv8 is just so much nicer to drive with superb get up and go and for the extra power and torque you loose very little in fuel economy (in fact some of have found the TDv8 to be more economical on fuel) if you can resist the temptation to play at hot hatches/ boy racers, something you cannot dream of doing in the v6. In two and half years of TDv6 ownership mine averaged 27.9 mpg by spreadsheet calculation and in 15 months so far my TDv8 has averaged 27.8mpg in 15k miles. The TDv8 also makes proper V8 noises whereas the v6 is muted. If the budget can extend to the TDv8 I would go for that. Specs are not hugely different but you get adaptive cruise as standard on the TDv8 which isn't even an option on the TDv6. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 ![]() ![]() ![]() |
Mercury os right, RRS is a cruising car, so speed is not a player but I would still get the V8... Far better choice... |
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 ![]() ![]() |
V8 is the way to go.... |
swiss Member Since: 13 Apr 2008 Location: Where the mountains and lakes are.... Posts: 42 ![]() ![]() ![]() |
V6 = 32A
skint Member Since: 05 Jan 2009 Location: N Essex Posts: 8 ![]() ![]() ![]() |
Just start each one up and listen. The chioce will be made for you!
Steve in germany Member Since: 15 Nov 2007 Location: Bad Lippspringe Germany Posts: 980 ![]() ![]() |
TDV8 |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 ![]() ![]() |
I love our TDV6 but having not been in a TDV8 I can't really comment.
