Home > Technical > sensors |
Have you tried washing the winter road muck off them? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Feb 21 2009 6:39pm |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 |
yea done that tim still does it |
Sat Feb 21 2009 6:55pm |
Is it the front or rear sensors? I have heard of them getting water inside the heads 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Feb 21 2009 7:07pm |
its the back tim iam gona give them a good clean tmrow il let yea know if it works |
Sat Feb 21 2009 7:40pm |
Just use plenty of cold fresh water, don't blast them with a high pressure though. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Feb 21 2009 7:46pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
Some water may have worked its way into one of the sensors, shorting it. Happens to ma quite often when it rains. As the water dries out, the problem may go away on its own. |
Sat Feb 21 2009 8:26pm |
So borrow your wife/girl friend's hairdryer and have a session of drying them out. Might be best to do it after dark or inside a garage otherwise the neighbours might think you've gone round the twist trying to dry your car with a hairdryer! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Feb 21 2009 9:50pm |
thanks for the info tim il try that |
Sat Feb 21 2009 10:03pm |
will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377 |
Mine is doing just that - it is going in Monday for a new module L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Sat Feb 21 2009 10:58pm |
richh Member Since: 15 Feb 2009 Location: england Posts: 9 |
if you turn thre ign. on to pos2 and put into reverse somewhere quiet, then literally put your ear to each sensor in turn you should hear a slight clicking noise (like a bat!) if there is only one not doing this noise then get it replaced, hope this helps, ichh. they all do that! |
Sun Feb 22 2009 11:24am |
all sorted now give them a good wash with freshwater as tim suggested back to normal thanks for advice guys |
Sun Feb 22 2009 2:24pm |
