Home > Technical > sensors
baxc
sensors
hi as any one had any problems with parking sensors mine have just started to emit a long bleep insted of an intermitant one wiped sensors clean but still does it any suggestions guys thanks
Post #213040 Sat Feb 21 2009 6:23pm
Tim in Scotland
Have you tried washing the winter road muck off them? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #213045 Sat Feb 21 2009 6:39pm
baxc
yea done that tim still does it
Post #213051 Sat Feb 21 2009 6:55pm
Tim in Scotland
Is it the front or rear sensors? I have heard of them getting water inside the heads 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #213054 Sat Feb 21 2009 7:07pm
baxc
its the back tim iam gona give them a good clean tmrow il let yea know if it works
Post #213062 Sat Feb 21 2009 7:40pm
Tim in Scotland
Just use plenty of cold fresh water, don't blast them with a high pressure though. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #213064 Sat Feb 21 2009 7:46pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
Some water may have worked its way into one of the sensors, shorting it. Happens to ma quite often when it rains. As the water dries out, the problem may go away on its own.
Post #213078 Sat Feb 21 2009 8:26pm
Tim in Scotland
So borrow your wife/girl friend's hairdryer and have a session of drying them out. Might be best to do it after dark or inside a garage otherwise the neighbours might think you've gone round the twist trying to dry your car with a hairdryer! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #213088 Sat Feb 21 2009 9:50pm
baxc
thanks for the info tim il try that Thumbs Up
Post #213090 Sat Feb 21 2009 10:03pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Mine is doing just that - it is going in Monday for a new module Thumbs Up L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #213107 Sat Feb 21 2009 10:58pm
richh
if you turn thre ign. on to pos2 and put into reverse somewhere quiet, then literally put your ear to each sensor in turn you should hear a slight clicking noise (like a bat!) if there is only one not doing this noise then get it replaced, hope this helps, ichh. they all do that!
Post #213174 Sun Feb 22 2009 11:24am
baxc
all sorted now give them a good wash with freshwater as tim suggested back to normal thanks for advice guys
Post #213189 Sun Feb 22 2009 2:24pm
