Home > Technical > Trolley Jack |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 |
Your average two tonne trolley jack will not raise the RRS enough to extend the suspension travel and lift the wheels off the floor I'm afraid.
Thu Feb 19 2009 4:14pm |
You will need a 3 tonne jack. A word of advise, once the car is jacked up put a spare wheel next to the jacking point just in case the jack fails. 2005 Zambezi TDV6 - Gone but not forgotten
Thu Feb 19 2009 4:35pm |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
what about one of the Airlift jacks that the Disco3 lads use that are pumbs via the exhaust gases |
Thu Feb 19 2009 4:51pm |
I've got one - They're good but you tend to get your hands dirty! 2005 Zambezi TDV6 - Gone but not forgotten
Thu Feb 19 2009 4:58pm |
I thought your butler always swapped the wheels over for you VA. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
Thu Feb 19 2009 5:15pm |
I was also told by the local tyre fitters to be very careful to put the trolley in the places shown in the manual, they had 2 very expensive "incidents" when Disco3 1st came out and they managed to jack the cars up with the jack under the suspension compressor. First time they changed my wheels over they asked for my owners manual as they had never had an RRS in the workshop before and they didn't want to muck up anything underneath 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Feb 19 2009 5:19pm |
Mintleaf Member Since: 18 Aug 2008 Location: London Posts: 77 |
Thanks for all the replies...will go for a 3 tonne jack even though one of Bobby's TSB say a 1.5 Tonne jack is ok... RR Sport TDV6 HSE 07MY Java Black |
Thu Feb 19 2009 5:50pm |
The trouble with the trolley jack is they are so easy to use, you can easily get carried away and try lifting the whole side of your vehicle so that both wheels are off the floor at the same time. The three tonne jack would make this possible with no risk of collapse. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
Thu Feb 19 2009 5:54pm |
i have just seen this one:
Thu Feb 19 2009 5:58pm |
I wouldn't use it! The car exceeds the weight limit. 2005 Zambezi TDV6 - Gone but not forgotten
Thu Feb 19 2009 6:05pm |
That jack also has a tiny lifting pad so all the weight is concentrated on a very small area, it needs a larger lifting area. Their 2t trolley jack (which I have and use for changing the wheels on my 90) has a bigger lifting pad.
Thu Feb 19 2009 6:22pm |
Pelyma Member Since: 28 Sep 2005 Location: Sussex Posts: 1497 |
2t will lift the car you are only lifting one side - not the whole car! look for one that will lift to 500mm. If you search the D3 site someone was making adaptors to fit where the scissor jack fits. Porsche Cayenne S Diesel 66 Plate |
Thu Feb 19 2009 6:59pm |
Thanks everyone...
Thu Feb 19 2009 7:02pm |
