![]() | Home > Technical > I want to connect to Aux input on Back of Radio |
pjb Member Since: 04 Mar 2008 Location: Sunny Oxon Posts: 213 ![]() |
Not sure but Bobby may have the info he'll be about soon if he can help RRS TDV6 Gone but still around
bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496 ![]() ![]() ![]() |
Try this PDF see if it has what you need. http://www.rrsport.co.uk/gallery/albums/userpics/10362/audio.pdf
Thanks Pete
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
looks like a pdf of the london underground to me |
Your welcome. Follow Us On Twitter @bellautos |
You get used to them after a while. I must admit they look worse than they actualy are. Follow Us On Twitter @bellautos |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
Thats a perfect fit for a secondary screen. - Guess your car doesn't have bluetooth? 2022 P440e AB |
Sadly no, and having had land rover blue tooth before I thought I would try a different solution. Paul L405 Loire Blue Swift Conqueror 645 Abarth 500c |
Try these pics |
phataitch Member Since: 02 Feb 2009 Location: hampshire Posts: 6 ![]() ![]() ![]() |
Firstly, thanks very much for such a speedy response.
So I investigated and whilst I'm convinced the wires in the back are the right ones, they don't go anywhere !! Connector in front pass footwell doesn't contain those wires coming from the stereo ! So, I conclude that LR didn't fit any aux wiring to the XS !
So i took the plunge and removed the radio, identified the connectors required (not the easiest thing to find the right ones !) and connected them to the wiring block. All works well, ipod cable comes up by the ciggy lighter (tapped into the wires here too so it charges) and no issues with volume levels.
Nice job |
