Home > Technical > I want to connect to Aux input on Back of Radio
pjb
Does anyone know the pin configurations on the back of the radio as I want to connect to the aux input behind the dash ?
Standard 6 Disc Harmon Kardon head unit.
I've put in a bluetouch screen in the air vent and want to use the ipod connectivity, that comes with it, and it would be easier to connect direct into the back of the radio rather than have to run a cable back to the aux socket.
Many Thanks
Paul
 Paul
L405 Loire Blue
Swift Conqueror 645
Abarth 500c
Post #203140 Sat Jan 03 2009 4:54pm
Not sure but Bobby may have the info he'll be about soon if he can help RRS TDV6 Gone but still around
Post #203144 Sat Jan 03 2009 5:16pm
bellautos
United Kingdom 2005 Range Rover Sport TDV6 HSE Cairns Blue
Try this PDF see if it has what you need. http://www.rrsport.co.uk/gallery/albums/userpics/10362/audio.pdf
Regards Pete
Post #203148 Sat Jan 03 2009 5:34pm
pjb
Thanks Pete
Exactly what I needed Very Happy
Now I've got a job for Sunday Crying or Very sad Paul
L405 Loire Blue
Swift Conqueror 645
Abarth 500c
Post #203153 Sat Jan 03 2009 7:08pm
looks like a pdf of the london underground to me Embarassed
Post #203155 Sat Jan 03 2009 7:18pm
bellautos
pjb wrote:
Thanks Pete
Your welcome.
Post #203159 Sat Jan 03 2009 7:45pm
bellautos
You get used to them after a while.
I must admit they look worse than they actualy are.
Post #203160 Sat Jan 03 2009 7:49pm
PauloAmore
Scotland
Re: I want to connect to Aux input on Back of Radio
pjb wrote:
Thats a perfect fit for a secondary screen.
- Guess your car doesn't have bluetooth? 2022 P440e AB
Post #203183 Sat Jan 03 2009 11:28pm
pjb
Sadly no, and having had land rover blue tooth before I thought I would try a different solution. Paul
L405 Loire Blue
Swift Conqueror 645
Abarth 500c
Post #203191 Sun Jan 04 2009 7:39am
phataitch
United Kingdom 2008 Range Rover Sport TDV6 S Santorini Black
Pete
Sorry to dig up and 'old' post, but i could do with a little advice.
Looking on the diagrams you posted, I've been trying to locate the wiring for the aux connector (red, blue and black wires). I have a XS (which I'm guessing is no different to a S model, electrically) so am assuming the low-line audio. Would I be correct in saying that although the head units are the same between low line and high line, there's no wiring from the head unit in the low line for an aux connector ? (I've been looking in the passenger footwell too and can't find the wires).
If not, can I buy the connector and wire it myself or is it only included as part of the kit ?
I've removed the ashtray in the rear behind the centre console where the aux connector would go on higher spec models and I have located a blue red and black set of wires going into a green plug, but not sure if these are for something else e.g. heated seats ?
Does anyone else have a picture of the connector that goes into the back of the radio ?
Thanks all for any help you can give.
Hayden
Post #212016 Mon Feb 16 2009 11:18pm
bellautos
Try these pics Smile im unsure about the wireing to be honest, ive not looked at a car without the wires and socket socket already there.
if the wires arnt there then you can add them your self i would think.
http://www.rrsport.co.uk/gallery/albums/userpics/10362/C2831.pdf
http://www.rrsport.co.uk/gallery/albums/userpics/10362/C2115.pdf
Post #212021 Mon Feb 16 2009 11:50pm
phataitch
Firstly, thanks very much for such a speedy response.
In that first link, the green connector and associated wiring looks very similar. If this is correct, it then begs the question, if it's in the rear console, it should also be in the passenger footwell, shouldn't it ?
I'll investigate further tomorrow and I'll multi meter the wires as I don't think they'll carry any significant voltage if they're the right ones.
Once again thanks very much for a very helpful response.
Hayden
Post #212025 Tue Feb 17 2009 12:15am
phataitch
So I investigated and whilst I'm convinced the wires in the back are the right ones, they don't go anywhere !! Connector in front pass footwell doesn't contain those wires coming from the stereo ! So, I conclude that LR didn't fit any aux wiring to the XS !
Next ? Radio out !!!
Thanks for your help
Hayden
Post #212572 Thu Feb 19 2009 4:30pm
phataitch
So i took the plunge and removed the radio, identified the connectors required (not the easiest thing to find the right ones !) and connected them to the wiring block. All works well, ipod cable comes up by the ciggy lighter (tapped into the wires here too so it charges) and no issues with volume levels.
Once i'd identified and ordered the bits I needed (about £12 in total, including the ipod cable) it took me just under 2 hours to complete, from start to finish. Very satisfied with the result.
Thanks for the wiring diagrams and photos, Pete. Very, very useful. The only downside ? No steering controls for the ipod tracks. Not the end of the world for me, as it's in a very reachable place down by the heater controls.
In conclusion, you can buy a cheap RRS (XS) and have an ipod !! Don't let the dealers tell you otherwise Very Happy
Hayden
Post #215681 Fri Mar 06 2009 11:52pm
bellautos
Nice job Smile Im glad you have sorted it.
Regards Pete
Post #215682 Sat Mar 07 2009 12:03am
