![]() | Home > Technical > How can I enable all doors to unlock together? |
yes, it's part of the setup. ISTR it can be done through the settings button or by your dealer. Bodsys Brake Bible
mr_moped Member Since: 02 Dec 2008 Location: Cheshire Posts: 81 ![]() ![]() ![]() |
ISRT?
Frozen of Wiltshire Member Since: 08 Jan 2009 Location: Wiltshire Posts: 66 ![]() ![]() ![]() |
Not sure what you mean exactly - but when getting into a locked car if you press the unlock button on the key fob twice all doors will unlock (at least on my car they do) and I don't think theres anything you need to set for that - didn't see any mention about changing it in the manual anywhere so should be standard. Is that what you're after or do you mean something different? Range Rover Sport TDV8 HSE, Buckingham Blue with Ebony Black
Frozen of Wiltshire - My car has the same locking operation as yours! I was wondering if all the doors can be unlocked with a single key press instead of two?
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 ![]() ![]() ![]() |
Set the ignition key to position two and scroll through your information button. You can switch off single point entry option in the set up menu. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
Is it " Lazy unlock"? If so I know how to do that |
Could be, it's been a while since I have had call to scroll through that particular menu. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
same as setting overspeed warning, auto door lock when drive off or mirror dip when in reverse.....put the car in park, press the info button until settings menu appears on screen next to speedo, use music tracck up and down buttons to scroll options and use volume up and down buttons on steering wheel to change. |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Lazy Unlock, really?
Nice one umbertob!
Thats the one !!! Press and hold both buttons on the keyfob . How did I forget about that one. |
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 ![]() ![]() |
The lazy unlock mode is for altering the drivers seat and steering wheel settings for different drivers providing they use different sets of keys. If turned on the car knows which settings relate to which set of keys and adjusts to suit.
That describes Lazy Entry, though. Never heard of Lazy Unlock - unless LR added a menu option with that name since my 2006 model came out. |
Sorry.....I meant Lazy Entry |
