![]() | Home > Technical > Large Oil Leak - V8 supercharged - any known issues? |
Have you had a it serviced recently or done an oil change yourself? Have you checked the sump plug is still tight.
B9 PSW Member Since: 24 Oct 2008 Location: Manchester Posts: 4 ![]() ![]() ![]() |
Thanks Tim,
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Any signs of tampering with the car whilst in the car park?? |
Apparently it is a design fault. Some tube has worn a hole through as it bounces about. Will find out the details tonight and publish it. I had read of a similar fault with the V8 RR (not Sport). Doesn't sound too expensive (I hope)
Sorry we weren't able to help, but at least you have found the cause. We don't have that meny members here with S/C's and those that have them don't seem to suffer too many mechanical woes. How old is the car B9, because you might find your dealer will replace the hose as a goodwill repair if the price isn't very much. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Dear all thanks for your advice - turned out to be a known design fault, although Land Rover won't admit to it!
Oil out of pavers - Halfords sell something called GUNK - it's for cleaning garage floors and you can buy it in up to 5lt canisters, usually works well if applied with a stiff brush IIRC the can is coloured red. There is also a cleaner called Muck Off - it's a biodegradable bike cleaner (not a cleaner for biodegradable bikes though |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
