Home > Technical > Large Oil Leak - V8 supercharged - any known issues? |
Have you had a it serviced recently or done an oil change yourself? Have you checked the sump plug is still tight.
Wed Jan 28 2009 9:53pm |
B9 PSW Member Since: 24 Oct 2008 Location: Manchester Posts: 4 |
Thanks Tim,
Thu Jan 29 2009 9:56am |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Any signs of tampering with the car whilst in the car park?? |
Thu Jan 29 2009 12:54pm |
Apparently it is a design fault. Some tube has worn a hole through as it bounces about. Will find out the details tonight and publish it. I had read of a similar fault with the V8 RR (not Sport). Doesn't sound too expensive (I hope)
Thu Jan 29 2009 5:53pm |
Sorry we weren't able to help, but at least you have found the cause. We don't have that meny members here with S/C's and those that have them don't seem to suffer too many mechanical woes. How old is the car B9, because you might find your dealer will replace the hose as a goodwill repair if the price isn't very much. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Jan 29 2009 6:11pm |
Dear all thanks for your advice - turned out to be a known design fault, although Land Rover won't admit to it!
Sat Jan 31 2009 7:21pm |
Oil out of pavers - Halfords sell something called GUNK - it's for cleaning garage floors and you can buy it in up to 5lt canisters, usually works well if applied with a stiff brush IIRC the can is coloured red. There is also a cleaner called Muck Off - it's a biodegradable bike cleaner (not a cleaner for biodegradable bikes though ) and it's quite good too but much more expensive than Gunk.
Sat Jan 31 2009 9:31pm |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 |
Sun Feb 01 2009 12:53am |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
RRS TDV6 Gone but still around
Sun Feb 01 2009 11:07am |
