Home > General > Welcome to RRSPORT.CO.UK - say hello here!
Page 113 of 383 <123 ... 112113114 ... 381382383>
fairwx
United Kingdom 2009 Range Rover Sport TDV6 HSE Buckingham Blue
RRS's are quite common in my part of the world, but they are all black or grey.
I decided to give my local dealer a shock and order a Buckingham Blue one!
I think it going to arrive in March, providing JLR keep the factory open...
Post #208805 Wed Jan 28 2009 5:27pm
Tim in Scotland
Welcome FairWx, your one is probably sitting in a field somewhere, it's just that it will take the parking attendants 2 months to shuffle all the other cars around to get to the Buck Blue with your name on it....................Mr. Green 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #208811 Wed Jan 28 2009 5:52pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
fairwx wrote:
Hello all, ordered a 09MY RRS, currently in an Audi A5 and fed up of sitting on the tarmack.
Nice to find a forum dedciated to the new vehicle!
Welcome fairwx.............got bored with being referred to a c*ck then, welcome aboard Thumbs Up
Whistle Whistle L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #208887 Thu Jan 29 2009 12:45am
hola will welcome back Wink
Post #208914 Thu Jan 29 2009 7:57am
McBunny
Germany 2006 Range Rover Sport TDV6 HSE Bonatti Grey
WElcome everybody I missed. Embarassed Very Happy RRS TDV6 HSE, 2006, bonatti grey, ebony interior, rear diff, s/c grille and vents, stormers, privacy, tasmods, iphone integration Wink
Post #208995 Thu Jan 29 2009 12:09pm
Jonny Fresh
Welcome all newcomers......
from the very best of the 2008 Newcomers Whistle
Post #209004 Thu Jan 29 2009 12:29pm
NE71
Just joined an enjoy reading.
Post #209095 Thu Jan 29 2009 5:00pm
Welcome RRS TDV6 Gone but still around
Post #209101 Thu Jan 29 2009 6:05pm
RRSKildare
Ireland 2006 Range Rover Sport TDV6 HSE Java Black
Hi All,
Glad to be a part of this.
Let me begin by thanking you all for your selfless contributions which have enabled me to improve my driving experience.
I joined a few months ago after purchasing a 2006 Java Black TDV6 RRS on new Vogue SE 20", Alpaca and a Kahn quad exhaust.
During the past 2 years I've gone through: -
2002 E39 530d, 2005 Nissan Patrol LWB (big but horrible), 2005 LC100 (solid as a solid thing, but had a prob with turbo that nobody could resolve). Needless to say, I have been a one man slush fund for Irish car dealers. The reason for this fickleness is my incessant and painful craving for perfection.
Boy did I make a bad decision with the RRS in that regard. But what a car!
I've recently got the car back from the stealer for warranty work on the following: -
Knocking from rear:-
When driving at low speads over rough terrain, I can hear a hollow sounding knocking coming from the rear of the car which is getting worse over time. This has crept in over the past 1000km. I am also starting to 'feel' the noise through the floor of the car.
what the stealer said: - replaced ARB bushes on 4 corners
My thoughts: - ahhh, no more knocking
Driveline shunt: -
When slowing to a crawl at ramps etc and taking my foot off the throttle, when reapplying throttle, the transmission slams into gear resulting in a mild to severe shunt depending on how much throttle is applied. In order to minimise the shunt, it can take several seconds to very gently apply throttle during which time the car can roll to a complete stop. This doesn't happen from a standing start with brake previously applied.
What the stealer said: - We've updated the software, please drive carefully for 200 miles.
My Thoughts: - Some improvement but still shunts - not happy
Rear passenger doors not opening: -
The locks on both the rear doors (not tailgate) are not always opening. This was originally only happening with the rear passenger side but has started to occur with the rear driver’s door also. I can get the doors to unlock from inside the vehicle by applying light outward pressure to the lock on the door panel as the unlock button is pressed on the dash.
What the stealer said: - replaced locks
My Thoughts: - They certainly sound different when locking and problem hasn't reoccurred
Compressor noise: -
The air suspension is extremely noisy when the car is being raised and far noisier than other RRS's or D3's that I have been in.
What the stealer said: - brackets broken, cough up
My Thoughts: - :censored:
Tailgate rattle: -
The tailgate is making noise when driving over ramps etc. I can stop this by applying a small piece of rubber between the plastic surfaces that touch each other at the centre where there appears to be a rubber buffer at the lockplate (main tailgate door) so that the plastic surfaces are not rubbing against each other.
What the stealer said: - we've modified it
My Thoughts: - looks exactly the same to me - even left the rubber pads on, still, it's been quiet for some time.
Seatbelt warning: -
The seatbelt warning buzzer is coming on from time to time even though there is only the driver in the car with seatbelt applied. I can stop this by applying pressure to the surface of the front passenger seat.
What the stealer said: - we've fixed it
My Thoughts: - remains to be seen (heard)
Front wipers dragging: -
The front wipers drag across the screen especially in cold conditions. I can stop this by applying rain-x type solution.
What the stealer said: - it happens
My Thoughts: - can’t wait for the Valeo X-TRM wipers to arrive
Rattle from passenger side front headlight lens at idle: -
as per description.
What the stealer said: - we took it out and tightened a bracket
My Thoughts: - haven’t checked it but have no reason to doubt them - yet...
Need to keep increasing the temperature setting to keep the cabin warm while driving:-
as per description -
What the stealer said: - The heater warms the car up and cools it down - it's fine
My Thoughts: - to**ers
Exhaust lower on one side: -
The driver’s side exhaust appears to be hanging considerably lower than the passenger side
What the stealer said: - nothing
My Thoughts: - will fix it myself, I think the tailpipe just needs to be turned slightly
I've also purchased the switchable remap solution from Imran and love the difference it has made. I'll post separately on that.
On a different topic, I bought me car from 'Derek Burton 4x4' in Co. Wicklow, Ireland. They are wonderful and really know their stuff. They re not a main dealer but arranged for the warranty work to be done at such a garage. I'm happy enough with the main dealer which was Spirit Motor Group in Sandyford, Dublin. Didn't get a lender though.
That's it for this post.
Cheers all !!!
Post #209170 Fri Jan 30 2009 11:51am
Jonty
Location: Sat with my head in my hands wondering what the hell I'm doing
TB - Is there an award for longest 1st post Question Whistle Whistle
@RRSKildare -sounds like you've been through the mill a bit with the RRS Sad
Welcome to the Forum anyway Thumbs Up Thumbs Up Current: I can't say...Oh the Shame!
Gone: 2003 Audi S4 - 340BHP of Fun Smile
Gone: 2005 RRS SE, Silver, Chrome Mirrors, Tinted with a stupid spare wheel!
Gone: Audi A4 2.5 TDi Quattro 180bhp
Gone: BMW 535i
Gone: 1985 Audi Quattro Sad Sad
Gone: Subaru Imprezza Turbo (rubbish)
Post #209201 Fri Jan 30 2009 4:22pm
no sh** Censored Laughing welcome Wink
Post #209214 Fri Jan 30 2009 5:04pm
Thats more them all my post put together Rolling with laughter Rolling with laughter
Welcome Thumbs Up RRS TDV6 Gone but still around
Post #209238 Fri Jan 30 2009 6:46pm
RRSKildare
That's the cut down version ...
Post #209323 Sat Jan 31 2009 5:13pm
Shocked Laughing
Post #209331 Sat Jan 31 2009 5:46pm
McBunny
Welcome!
Thank god, now there is somebody who posts longer posts than me! Very Happy Thumbs Up RRS TDV6 HSE, 2006, bonatti grey, ebony interior, rear diff, s/c grille and vents, stormers, privacy, tasmods, iphone integration Wink
Post #209642 Mon Feb 02 2009 1:49pm
