![]() | Home > Technical > DPF |
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 ![]() ![]() ![]() |
Bobby, thanks anyway... |
I think you must insist the dealer checks all the things related to the DPF, especially the software. I'm sure they can update the software. Having said that I'm surprised with the 'Engine System Fault' message. My limited knowledge tells me that when the DPF becomes full the driver is alerted with a 'DPF FULL' message. You should then drive the vehicle until the engine is at its normal operating temperature and then drive for a further 20 minutes at speeds not less than 30 mph (48 km/h). Would be better if you can go really fast! Anyway, if the regeneration is successful the 'DPF FULL' message will go off. If the software still detects that the DPF is full/blocked, this message 'DPF FULL VISIT DEALER' will appear. Suffice to say, a trip to the dealer is recommended to have the DPF force regenerated. This is when you should insist on a full check-up! Engine System Fault is different. Hope this makes sense... coffee wearing off! ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
What you ssaying does make sense. Unfortunately the car itself does not... And that mainly because the messages come as the they wish...
You got me there, mate! ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
McBunny Member Since: 18 Sep 2008 Location: South Posts: 679 ![]() ![]() ![]() |
In fact I heard the same from guys in Germany who had the DPF as standard and only drive through town. Seems you just have to do a weekend-trip every week, that's all! |
Rower, are you sure that is the DPF doing a cleaning cycle. When I had the TDv6 it used to sound quite strained some mornings after starting and not on others. I took it to the dealer and they said it was the gearbox oil cooler going through a check cycle! My FFRR did the same thing and neither car had the DPF fitted. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
gear box oilcooler
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Which dealer you using? |
Marshall Lincoln...
Killerbob Member Since: 27 Sep 2008 Location: St. Gallen Posts: 145 ![]() ![]() ![]() |
I don't think so. I just this morning had the "DPF Full - See Manual" message, and I only have put 6'500KM on the car since new. It has been about two weeks since I went on a longer drive (>20KM), but only ca. 175KM, and I have added a mix of 1/200 semi-synthetic 2-stroke oil into the diesel all along. I did the "2'500RPMs for 20 minutes", and the message went away, but it left me wondering what prompted the error in this case? KB RRS TDV8, black with ivory. |
KB, after I had the sensor exchanged (just search for the post where I mention it) I do not have any problems.
It is supposedly also an issue to remove the DPF here in Switzerland.
Mate to remove the damn thing is not issue of a country. It is LR that does not allow me to do so because of ECU (their claim at least |
OK, but according to my stealer, the Swiss are also requiring all new diesel cars to be fitted with a DPF, or pay more in taxes. RRS TDV8, black with ivory. |
