![]() | Home > Technical > [FAQ] WARNING - DOES YOUR FRONT SUSPENSION KNOCK? |
Hooky Member Since: 18 Dec 2008 Location: North West Posts: 28 ![]() ![]() ![]() |
Given we are all good at bitching about this why isn't there a mad rush to take direct action to Land Rover and make our collective voices heard?
rrspoland Member Since: 04 Dec 2008 Location: Warsaw Posts: 123 ![]() ![]() ![]() |
I am not very experienced yet as a rrs owner although I thought I would share my 2 theories on the knocking suspension.
Good theory, but unfortunately have tried the use and abuse option and if anything it got worse. |
thanks. so is yours |
Aww. RRS TDV6 Gone but still around
Get a room!! |
You can say that again! |
Get a room!! |
Jees |
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 ![]() ![]() |
ok my car is at the dealers today lets see what happens... |
got the car back doesn't knock anymore |
So Angel - what wonder fix have they done for you? Is it: A. Bushes B. Drop arms C. Shims or D. A.n. other ?? L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now! 5 series for the miles ![]() RRS S/C factory built HST - Gone 45 others have been and gone! |
bananaman Member Since: 22 Jan 2009 Location: uk Posts: 7 ![]() |
iv not got time to read all the relpies on here but what i do know is that the sport front susp knock is normally stabilizer bar bushes, bottom ball joints (there has been an updated part release) or stabilizer bar knock. i do know for a fact that landrover are trialling an updated stabilizer bar assy with reduced clearances etc to try and cure the operation knock but these are not available at dealers and may not be for some time. also land rover say that the body dampers on the front can be removed as these can cause knocking and removing them isnt detrimental to the vehicle. the rear ones MUST STAY ON THE VEHICLE |
Hmm, interesting Bananaman.........had not heard about the stabiliser bar, the rest {unfortunately} is not doing the trick, hence our frustration |
