![]() | Home > Technical > PTI Question |
No it will come on when you turn the BT on |
Wozz Member Since: 28 Dec 2008 Location: Cheshire, United Kingdom Posts: 826 ![]() |
BT? WINNER - 2009 Best Newcomer Award
Bluetooth 2005 Zambezi TDV6 - Gone but not forgotten
Bluetooth = BT when talking about PTI and what not |
I thought Bluetooth was an always on situation? WINNER - 2009 Best Newcomer Award
No if i remember right you have to have the radio/cd on for the PTI to work
Ok thanks mate for the reply.
It is a bit of a bummer but i never drive without the sounds on |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Same here - audio usually on - but can you not set the audio levels low so when you use PTI the audio levels do not disturb - i have not fathomed yet the news bulletins and often get the system chopping through 3 or four channels on the hour all at different audio levels
Sure you could can't see why not but i bet it's not that easy?
I usually have the music on but some days when I have a lot of work calls to make I switch the sounds off. Seems daft having a system that only lets you make a call if you have music on but its not a big deal - I was just wondering if it was configurable. WINNER - 2009 Best Newcomer Award
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 ![]() ![]() ![]() |
Set the system to AUX instead of Sat 1 or Sat 2 and disconnect your IPOD (if you have one), then you'll have BT available, but no background noise. PJPR
I was just about to say that |
I was doing that but when i finished the call it would drop out to radio and not back to AUX channel.
