Home > Technical > Heated washer jets?
Page 2 of 3 <123>
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
Only the nozzles are heated, if the washer fluid is frozen in the tubes you won't get any screen wash until everything defrosts.
The heated side mirrors come on with the ignition, they are not connected to the heated scfreen or any other heating system in the vehicle. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #203624 Tue Jan 06 2009 12:59am
Bobby
In addition to all the above...
Heated Windshield Washer Jets
Two windshield washer jets are used, each jet containing a non-return valve to prevent washer fluid draining back to the reservoir and also to limit the amount of washer fluid, which can be forced by gravity from the jet during cornering.
Each washer jet contains a heater element, which prevents the fluid freezing in the nozzles in very cold conditions and a Positive Temperature Coefficient (PTC) sensor, which regulates the temperature. The jet heater elements are controlled by the Automatic Temperature Control (ATC) module and a heated washer jet relay in the BJB.
 Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #203629 Tue Jan 06 2009 6:50am
Davel
England 2007 Range Rover Sport TDV6 HSE Java Black
Very good - but they don't f***ing function in mine.
Big Cry
They did in my Touareg though!
Post #203659 Tue Jan 06 2009 9:23am
Nor do mine! 2005 Zambezi TDV6 - Gone but not forgotten
Post #203660 Tue Jan 06 2009 9:23am
Bobby
Don't look at me! Rolling Eyes Shocked
I don't have this either!! Sad
Laughing Laughing Malaysia Boleh!
Post #203665 Tue Jan 06 2009 9:54am
Poor Bobby, you try and help and what happens? Laughing
As TB was saying, if the water in the tube from the reservoir to the nozzle is frozen, this probably explains why a lot of water isn't coming out. Doesn't often take long for those tubes to defrost once your underway Very Happy
Post #203675 Tue Jan 06 2009 11:43am
Bobby
shmoogle wrote:
Poor Bobby, you try and help and what happens? Laughing Very Happy
Rolling with laughter Rolling with laughter Thumbs Up Malaysia Boleh!
Post #203676 Tue Jan 06 2009 11:46am
jmm
France 2008 Range Rover Sport TDV6 HSE Tonga Green
Last week in Denmark we reached -9C° and the washer jet worked perfectly. What are NOT working are the headlights cleaners Sad Sad at that's a real pain in the Censored since with all the chemical they spray on the roads the headlamps efficiency is reduced to almost nil.
Post #203831 Wed Jan 07 2009 9:19am
hmm both worked here perfectly at - 7 degrees Smile
Post #203843 Wed Jan 07 2009 10:01am
jetblasters
2005 Range Rover Sport TDV6 Java Black
Morning!
I am suffering from no water either - and I don't even hear a wherring noise from the pump - the head light ones work fine though. Off to check the fuse box to see if I tried using it when it was frozen solid.
Stuart
Post #203851 Wed Jan 07 2009 10:55am
jetblasters
yep, 10A fuse blown!
d'oh.
Post #203891 Wed Jan 07 2009 1:09pm
dadanek
Czech Republic 2007 Range Rover Sport Supercharged Java Black
Maybe OT...
How big is the washer fluid tank? Today I bought a 5 litre bottle and the tank in range is still not full RANGE ROVER, MORE THAN A CAR, LESS THAN A KITKAT
Post #203895 Wed Jan 07 2009 1:12pm
jetblasters
9L from memory.
Post #203896 Wed Jan 07 2009 1:14pm
jamiepyoung
d'oh.
Thanks!!
I was beginning to thinks ours was blocked! Didn't think about checking a fuse. Ours was blown as well....
Post #204080 Wed Jan 07 2009 10:10pm
Did you change the fuse? Did it fit the problem? RRS TDV6 Gone but still around
Post #204104 Wed Jan 07 2009 10:40pm
Page 2 of 3 <123>
