![]() | Home > Off Topic > 3G Iphone on 3 UK |
bump - any takers ? L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
dadanek Member Since: 30 Mar 2008 Location: Heart of Europe Posts: 450 ![]() ![]() ![]() |
I have 3G...but absolutely dont know what you talking about |
crowej Member Since: 21 Apr 2008 Location: Dublin Posts: 289 ![]() ![]() ![]() |
this is the place to check
jambo Member Since: 31 Aug 2008 Location: Stoke on Trent Posts: 59 ![]() ![]() ![]() |
can't comment on 3 network but I've unlocked from O2 and had it happily running on Orange for the best part of 2 days now. I do have to warn you that the unlocking software isn't that great at the moment, still a couple of bugs to iron out, and it is a bit of a long winded solution. At the moment i've had a 50 / 50 success rate at managing to unlock the 3G one's - one worked and the other one seemd to load all th software ok but then its killed the wifi connection on the phone. I believe that another soilution should be out very shortly that is a simple 20 second unlock without the need to upload seperate programmes and turn the flight mode on and off, the 3g on and off and all the other things that you need to do to get the yellowsnOw version to work.
Thanks guys, I will go buy one tonight and fingers crossed it works with the 3 SIM.....otherwise, it will be for sale tomorrow !! |
Are you doing the unlock yourself or buying an unlocked one?
Thanks for the tip. I will be doing it myself. I have unlocked many before, but just never had a 3 UK contract before, so was unsure as to whether it will work. I will know for sure in about 2 hours !! ![]() 5 series for the miles ![]() RRS S/C factory built HST - Gone 45 others have been and gone! |
After i had jailbroken the phone using winpwn i tried the unlock i found that i couldn't get it to work with the version of yellowsnow i downloaded and installed via cydia. I had to use the version that you can download with the Installer application. I also used the bigboss tools to turn off the 3g and edge connections then reboot using big boss, then i installed the yellowsnow file, the rebooted again using bigboss tools - put the new sim in and then left it for 15 mins to log itself back onto the network - like i said before worked on one phone but not on the other one. |
