Home > Technical > Tailgate Opening
Jonnylp
Tailgate Opening
For some strange reason my tailgate opened slightly without any reason and the warning light on the dash is advising that the tailgate is open and the car wont lock.
I have tried to open the tailgate in order to close it properly however it seems stuck. Not too sure if it's the upper winder or the actual tailgate but now the vehicle is unlockable.
Is this a common fault on the RRS ? (2006, 2.7TDV6). IS it the lock or faulty mechanism ?
I know on my old Audi the passenger door lock did this and Audi knew it was a common occurence and replaced the mechanism.
I think it has opened on its own a few times over the last few months.
Any suggestions are gratefully accepted.
Post #203398 Mon Jan 05 2009 10:09am
First I've heard about this. Can you push firmly down to close? 2005 Zambezi TDV6 - Gone but not forgotten
Post #203400 Mon Jan 05 2009 10:17am
Jonnylp
Tried that and you can tell its open slightly but wont close.
There is nothing in the boot either so its not as though somethign is trapping the lock etc.
Very strange. Its only happened a couple of times when my wife has been driving along in it and it just pops open slightly !!
Think I will run it into the dealers and see what they can find.
Is there a by-pass so that the rest of the car can be locked ?
Post #203401 Mon Jan 05 2009 10:26am
No there's no by-pass. Try opening the other half of the boot. (Just interested to see what happens.) A trip to LR service centre is the best thing to do. 2005 Zambezi TDV6 - Gone but not forgotten
Post #203402 Mon Jan 05 2009 10:29am
MAW
How did you try to open the boot to lock it the keyfob or button on the tailgate?
I seem to recall similar on my last RRS - it 'half' catches and then is stuck between wanting to be open and closed - i recall the button on the tailgate doesn't play but the keyfob button does it (assuming the spare fob button is programmed to the boot) - I also found that it is easy to open the boot in error by inadvertantly pressing the spare keyfob button....
Hope that makes sense - Confused
Post #203404 Mon Jan 05 2009 10:35am
Jonnylp
Ah well not to worry I will try to get to the LR centre and get it checked out.
Once I get home I will try to open it with a little force but the top part wont open as I think it recognises that the bottom is not closed.
I am not with the vehicle at the moment as my wife has it. She rang me to tell me of the problem.
Thanks for the suggestions.
Post #203408 Mon Jan 05 2009 10:43am
Bobby
Did you try the Master Lock/Unlock on the dash?
Press the Unlock button to unlock all the doors.
Press both the Unlock and Lock buttons simultaneously for 3 seconds to release the whole tailgate. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #203409 Mon Jan 05 2009 10:44am
cyberjes
2008 Range Rover Sport TDV8 HSE Buckingham Blue
in my case, it turned out that i was shutting the door too hard.
(well it's a pretty heavy door to begin with, you know.)
try shutting it shoftly. the door retracts electronically.
never a half chut door since then. Thumbs Up MY08 TDV8 HSE
Buckingham Blue / Ebony / Lined oak / 19" Factory / Sunroof / Roof rail / Ipod Dock
Post #203412 Mon Jan 05 2009 10:47am
MAW
Shocked that works - !! - how did you know that Question (not a case of RTFM is it Embarassed ) I didn't know it did that and useful !!!!!!!!!
Post #203414 Mon Jan 05 2009 10:49am
Don't question Bobby he's a man in the know Thumbs Up RRS TDV6 Gone but still around
Post #203415 Mon Jan 05 2009 10:50am
MAW
I know - i just shot out to try it before that post Thumbs Up
Post #203418 Mon Jan 05 2009 10:52am
MAW
Jonnylp's is an 06 and that doesn't have the egate though
Post #203419 Mon Jan 05 2009 10:53am
Bobby
I hope it works for Jonnylp though. Wink
Thumbs Up Malaysia Boleh!
Post #203424 Mon Jan 05 2009 11:06am
Jonnylp
Appreciate all this info, will give the wife a call at lunch to try the 'master switch' solution.
Will keep you posted.
Thanks again for both the knowledge and speed of response which is extremely helpful. Thumbs Up
Post #203430 Mon Jan 05 2009 11:48am
Bobby you should come to one of our meetings in Europe - ITS A MUST to know you in real life Wink
Post #203445 Mon Jan 05 2009 12:32pm
