Home > Technical > Can this be done ???
Page 1 of 3 123>
MAW
I wanted to run the car this morning to get it defrosted and warmed ready - started it up with one key and wanted to lock it with the other to secure it - just in case....
It appears you cannot do that - is there a workaround Confused Sad
VMT
Post #203405 Mon Jan 05 2009 11:38am
Get a timer on the FBH with a GSM unit and you can get the car ready by phone. It'll not heat the cabin up but as soon as you get in the car and start it hot air will come out of the vents. 2005 Zambezi TDV6 - Gone but not forgotten
Post #203406 Mon Jan 05 2009 11:41am
But with the FBH shouldn't it heat up quick anyway? RRS TDV6 Gone but still around
Post #203407 Mon Jan 05 2009 11:42am
MAW
Shocked like the idea - that a doable thing? (off the shelf package??)
Post #203410 Mon Jan 05 2009 11:46am
Even if you could all you'd have to do is smash the window and drive off
Thank you very much RRS TDV6 Gone but still around
Post #203413 Mon Jan 05 2009 11:48am
MAW
Laughing not much chance of that here but the idea was just to stop an opportunist passing the driveway seeing a RRS running but unoccupied
Thanks though Jay for your valued input Rolling Eyes
Laughing
Post #203416 Mon Jan 05 2009 11:51am
MAW - here you go. http://www.disco3.co.uk/forum/topic15454.html or you can get 10forcash to do it for you. Fitted about £400+VAT 2005 Zambezi TDV6 - Gone but not forgotten
Post #203417 Mon Jan 05 2009 11:51am
MAW
Thanks VA Thumbs Up
Post #203420 Mon Jan 05 2009 11:54am
It's true tho MAW
VA do you know if that can be fitted to any car/van Or is it just for the D3/RRS? RRS TDV6 Gone but still around
Post #203421 Mon Jan 05 2009 12:00pm
MAW
Interesting read - i think i will see if the manual lock from the passenger side works first though Confused
Post #203422 Mon Jan 05 2009 12:02pm
Mate try this
Open the drivers window then lock all the door's from the inside driver's door as well get out and see if you and open the car with the other key if not and you now have locked yourself out the window will be open for you to reach in and open the door from the inside RRS TDV6 Gone but still around
Post #203423 Mon Jan 05 2009 12:06pm
Jay - all diesels with a FBH I think. 2005 Zambezi TDV6 - Gone but not forgotten
Post #203425 Mon Jan 05 2009 12:09pm
I'd like to get this fitted to my van guess it can be fitted to that as well? RRS TDV6 Gone but still around
Post #203426 Mon Jan 05 2009 12:13pm
highbridgeflyer
Not sure if the XS has a FBH.....
Post #203427 Mon Jan 05 2009 12:18pm
crowej
Ireland 2006 Range Rover Sport TDV6 HSE Java Black
Re: Can this be done ???
VMT
you could always start her up,
open the drivers window,
close the door,
lock the doors through the open window,
close the window with the confort closing windows and then use the other key to open it later.
you might have to use the other key manually though with the lock on the passengers side
Post #203428 Mon Jan 05 2009 12:41pm
Page 1 of 3 123>
