Home > Technical > Side Steps |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
fitting instructions should be able to be found here
Wed Dec 31 2008 3:00pm |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
I know Umbertob removes his when he goes off roading so can't be that hard to fit RRS TDV6 Gone but still around
Wed Dec 31 2008 4:10pm |
filaborg Member Since: 03 Feb 2008 Location: Essex Posts: 161 |
do you know if you have to jack up the vehicle..... |
Wed Dec 31 2008 4:34pm |
when i swap my fl2's bar (for off roading) i do it laying down
Wed Dec 31 2008 4:37pm |
Any specialist tools required.... |
Wed Dec 31 2008 4:41pm |
i had a look at the fitting guide in the owners info link above and it looks like normal rachet set is needed nothing special, though you will have to tighten them to the correct nM with a torque wrench
Wed Dec 31 2008 4:45pm |
for some reason the fitting page wont download.... |
Wed Dec 31 2008 4:51pm |
Worked fine for me if i use IE and not Firefox, but its in my gallery now for you
Wed Dec 31 2008 5:19pm |
Wozz Member Since: 28 Dec 2008 Location: Cheshire, United Kingdom Posts: 826 |
I'd consider getting some of these if I could replace the originals at the end of my lease term. WINNER - 2009 Best Newcomer Award
Wed Dec 31 2008 5:30pm |
As with most of these add on bits it is simply a matter of replacing parts when you sell. I have all sorts attached and when the car is sold these bits will come off and new trim put on. Example - my bumber has a sodding big hole in it for the winch but I've already sourced a spare bumper pre sprayed to match the car's colour and a little time in the bodyshop and my car will be looking like a bog standard RRS again. Everything can be taken off! 2005 Zambezi TDV6 - Gone but not forgotten
Wed Dec 31 2008 5:39pm |
Thanks VA - thats opened up a whole raft of possibilities to modify my vehicle. I already have a contact selling some Overfinch alloys (can't remember whether he said they were 20" or 22") so will be looking ta those in the New Year. WINNER - 2009 Best Newcomer Award
Wed Dec 31 2008 7:05pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
It's very easy, no cutting involved, no need to lift the car (if you put it in off road height though, it'll be easier to slide under the chassis to tighten some bolts.) The OEM kit includes new trim pieces for the lower sills (so you can set the original trim aside and reinstall it on the car if you ever want to go back to stock look, leaving behind no traces of your side steps), with cutouts that match the position of the 6 brackets (3 per side) supporting the platforms. You will need a stubby or offset Phillips screwdriver to remove a couple of screw holding the trim in place inside the rear wheel well, and about the only thing you need to pay attention to are those little plastic yellow/white pushpins on the trim, which tend to get dislodged from the trim pieces as you take the originals out or put the replacements on, so they may not line up properly with their female counterparts on the sills. There are also a handful of plastic stud retainers for the trim located under the chassis that are equally easy to remove and replace. After removing the original trim you mount the brackets with the provided bolts and washers using a 13mm (or 17mm? Can't remember) socket. When the brackets are securely bolted on the body, snap the replacement trim over them, slide the steps over the brackets and screw them in place. Done. First time it may take you a couple of hours, but it's very easy (as JayMann correctly points out: "If Umbertob can do it, it can't be hard!" ) and you don't need any extra help, since the aluminum steps are light and easy to position for a single person. Happy New year everyone, we are not quite there yet here on the West Coast of the US. |
Thu Jan 01 2009 12:29am |
