Home > Technical > Side Steps
filaborg
Side Steps
Any of you guys fitted them, are they easy enough to do...do you need any specialist tools, is there any cutting involved.... I don't particularly want to pay someone else to do a job that surely is only be a few nuts and bolts.....
Any advice would be grateful, thanks.
Post #202648 Wed Dec 31 2008 2:17pm
fitting instructions should be able to be found here
http://www.ownerinfo.landrover.com/extfree2viewlrprod/index.jsp
I bought my FL2's side protection tubes on eBay (£100) and paid my dealer to fit them at the cost of 1 hours labour (£6Cool Very Happy
£168 cheap Very Happy compared to the dealers quote of just shy of £400 Rolling Eyes
Best check the cost of the fitting as dealers charges vary quite abit but i presume RRS side steps will be the same process
Post #202656 Wed Dec 31 2008 3:00pm
I know Umbertob removes his when he goes off roading so can't be that hard to fit Thumbs Up RRS TDV6 Gone but still around
Post #202665 Wed Dec 31 2008 4:10pm
filaborg
do you know if you have to jack up the vehicle.....
Post #202668 Wed Dec 31 2008 4:34pm
when i swap my fl2's bar (for off roading) i do it laying down Sad
But at least you can select off road height to give you more room Whistle
Post #202669 Wed Dec 31 2008 4:37pm
filaborg
Any specialist tools required....
Post #202670 Wed Dec 31 2008 4:41pm
i had a look at the fitting guide in the owners info link above and it looks like normal rachet set is needed nothing special, though you will have to tighten them to the correct nM with a torque wrench
if you have a quick look, select RRS, accessories and side steps are on the second page, the pdf give you what tools are needed and a step by step guide (no pun intended)
Post #202671 Wed Dec 31 2008 4:45pm
filaborg
for some reason the fitting page wont download....
Post #202672 Wed Dec 31 2008 4:51pm
Worked fine for me if i use IE and not Firefox, but its in my gallery now for you Thumbs Up
http://www.rrsport.co.uk/gallery/albums/us...0steps.pdf
Post #202678 Wed Dec 31 2008 5:19pm
Wozz
I'd consider getting some of these if I could replace the originals at the end of my lease term. WINNER - 2009 Best Newcomer Award
'09 TDV6 XS Stornaway Grey
'06 BMW 730 D SE (Gone)
'08 A4 TDi SLine Avant (Gone)
Large pack of Flake Cakes (Gone)
6 pack of Guiness (Gone)
Post #202679 Wed Dec 31 2008 5:30pm
As with most of these add on bits it is simply a matter of replacing parts when you sell. I have all sorts attached and when the car is sold these bits will come off and new trim put on. Example - my bumber has a sodding big hole in it for the winch but I've already sourced a spare bumper pre sprayed to match the car's colour and a little time in the bodyshop and my car will be looking like a bog standard RRS again. Everything can be taken off! 2005 Zambezi TDV6 - Gone but not forgotten
Post #202680 Wed Dec 31 2008 5:39pm
Wozz
Thanks VA - thats opened up a whole raft of possibilities to modify my vehicle. I already have a contact selling some Overfinch alloys (can't remember whether he said they were 20" or 22") so will be looking ta those in the New Year. WINNER - 2009 Best Newcomer Award
Post #202690 Wed Dec 31 2008 7:05pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
Re: Side Steps
It's very easy, no cutting involved, no need to lift the car (if you put it in off road height though, it'll be easier to slide under the chassis to tighten some bolts.) The OEM kit includes new trim pieces for the lower sills (so you can set the original trim aside and reinstall it on the car if you ever want to go back to stock look, leaving behind no traces of your side steps), with cutouts that match the position of the 6 brackets (3 per side) supporting the platforms. You will need a stubby or offset Phillips screwdriver to remove a couple of screw holding the trim in place inside the rear wheel well, and about the only thing you need to pay attention to are those little plastic yellow/white pushpins on the trim, which tend to get dislodged from the trim pieces as you take the originals out or put the replacements on, so they may not line up properly with their female counterparts on the sills. There are also a handful of plastic stud retainers for the trim located under the chassis that are equally easy to remove and replace. After removing the original trim you mount the brackets with the provided bolts and washers using a 13mm (or 17mm? Can't remember) socket. When the brackets are securely bolted on the body, snap the replacement trim over them, slide the steps over the brackets and screw them in place. Done. First time it may take you a couple of hours, but it's very easy (as JayMann correctly points out: "If Umbertob can do it, it can't be hard!" Wink ) and you don't need any extra help, since the aluminum steps are light and easy to position for a single person.
Happy New year everyone, we are not quite there yet here on the West Coast of the US. Very Happy
Post #202696 Thu Jan 01 2009 12:29am
