![]() | Home > General > borla installation |
canttouchthis Member Since: 08 Dec 2008 Location: USA Posts: 38 ![]() ![]() ![]() |
thanks for all the info, been a huge help GITRDONE |
Hell why not another |
CTRover Member Since: 06 Dec 2008 Location: CT Posts: 7 ![]() ![]() ![]() |
They way warranty's work in the US are that the part you modified or added on has to directly caused the problem you are trying to warranty with land rover. It is called the magnuson moss act. So for example if you put an aftermarket stereo in your car and something happened with the electrical system they would most likely not warranty it.
CTR: what is an example of something an exhaust would directly affect? |
Murdered out Member Since: 08 Feb 2008 Location: Arizona Posts: 324 ![]() ![]() ![]() |
true, I know what you mean. We have NO high end auto shops here in Tucson. NONE I cant belive it, I'd have to drive two hours up to Phoenix, and thats not worth a 4 hour round trip.
not much, maybe if they did a shiesty job and messed up your cat... an exhaust is pretty much safe, it just is a stupid pipe that fumes escapes from. I've never heard of someone having any problemds with their vehicle from an exhaust, if anything the exhaust will go bad before you have any issues linked directly to it. Maybe if you had a hooptie and and some ghetto home made exhaust which caused back flow issues and lack of pressure etc, then that would be a problem, but the fix would be to get a new exhaust. Does that help? maybe you can get a strut exhaust, the pipes are diamond encrusted, PM sexy pault he knows some people! ![]() ![]() ![]() |
I saw that garbage |
Also it always comes down to our dealership and how much they will work with you because they can really warranty anything they want regardless of mods. Since they are the only ones working on your car they can either be really cool about everything or real A-holes.
Thanks CTR |
