![]() | Home > Technical > Cat removal |
BigMart Member Since: 17 Mar 2007 Location: West Midlands Posts: 324 ![]() ![]() |
Hello Daz,
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 ![]() ![]() |
I might well look into it after Xmas, I'm lucky since my best mate owns an exhaust company called JACexhausts, I have to be careful not to advertise his services and abuse the advertising policy and get my knuckles wrapped by the moderators.
Sexy Pauly Member Since: 24 Aug 2008 Location: LAN DAN MATE Posts: 698 ![]() ![]() ![]() |
i removed a cat once was a messy experiance, blood and cuts everywhere! id recomend you dont let ya cat anywhere near your cars engine!
Daz,
My mate had a sport in his unit yesterday to fit HST end trims to a HSE that had been modified with a HST kit.
Murdered out Member Since: 08 Feb 2008 Location: Arizona Posts: 324 ![]() ![]() ![]() |
why not just by a full catback exhaust system....Rather than have some |
Dont cat back systems have any welds in them.............and also dont cat back systems start and the cat and go back.....thus leaving the cat in place?????
id love to have a system like the ferrari F430,
ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704 ![]() ![]() ![]() |
Just do it like omar had on his 355. Straight through pipes from engine iirc. Then anyone within a few miles will know your driving |
catbacks have no welds, they are madrel bent (if you get a good system), and then clamped on with a special adapter. If you start throwing in pieces of bent tubing thats not mandrel bent, it messes with the out flow of exhaust, which causes it too be very inefficient. If you get a catback you can easily get that section extended if you get a custom one, therefore it would connect closer to the headers and right before the cat. ![]() |
Sorry mate I was being flippent, all exhausts have weld construction somewhere if you are having silencers on the system. There is nothing wrong with a good TIG weld if it is strong and professionally done.
Pauly,
just spoke to Larini, they dont do that system anymore!
