![]() | Home > Maintenance & Modifications > Help with the removal of tail lights |
Markos Member Since: 09 Dec 2007 Location: Ljubljana Posts: 187 ![]() ![]() ![]() |
Please can anybody tell me how to remove the tail lights-I would like to put in my new LED lights |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 ![]() ![]() ![]() |
There isn't anything "physicaly" holding the tail light unit in place other than the two screws you have already mentioned. There are a couple of plastic "prongs" (for want of a better description) on the lamp unit, which line up with holes in the bodywork. This is what makes the unit hard to remove.
Thanks TB. Are those prongs on the outer side of the ligts (horizontal oposite side where the holes of the screws are) where there is almost no space?
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
The prongs are opposite the screws - i 'gripped' the light with one hand and then thumped the back of my hand to 'dislodge' the fitting rearwards if that makes sense. A good gaffer tape stuck to the light may also give you purchase - i was very wary of paint damage trying to lever between the paint and the light cluster.... |
MAW thanks to you too. I finally got out the light cluster |
You are welcome |
