Home > Technical > clicking noise from rear wheel
Murdered out
United States 2008 Range Rover Sport 4.4 V8 HSE Java Black
I have this strange clicking noise comming from the rear wheel area. I cant pinpoint it and when I drove at slower speeds its more prominent. just sounds like ((( Click...click...))) over and over again. I cant se anything in the brakes or in that area either. It's wierd and very annoying to have that noise comming from a nice vehicle.
Any ideas?
Post #198757 Sat Dec 06 2008 8:33pm
Possibly a rear drive shaft. 2005 Zambezi TDV6 - Gone but not forgotten
Post #198758 Sat Dec 06 2008 8:42pm
monkey9952
A Stone ? Laughing
Post #198759 Sat Dec 06 2008 8:55pm
Murdered out
figured it out, i raised my rear suspension up a few mm and it went away. I think I had it too low, and it wasnt happy with itself. Thumbs Up
Post #198767 Sat Dec 06 2008 10:50pm
Murdered out
its back, it seems like when the vehicle is slant towards that side and more pressure is applied to that wheel it starts clicking again. You know that sound of the the clicking when the vehicle raises, well it sounds similar but its only when I'm rolling. So when the vehicle is in "off-road" it doesnt click at all. but when I have it a bit lower than "normal hieght" its less but it still does it like if i'm turning leeft and the vehicle is leaning on that side. Its very wierd. I've visually inspected it and cant find anything wrong or catching.
where are the experts?
Post #199502 Fri Dec 12 2008 11:41pm
Bobby
side effects of your "Lowering Module"...? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #199510 Sat Dec 13 2008 3:00am
Murdered out
I dont think it is, its from the wheel/hub area, not the airbags/suspension. As the wheel spins it clicks.
Post #199515 Sat Dec 13 2008 4:27am
Bobby
Then could it be the EPB brake shoe retaining clip that has become dislodged/broken, that's causing this clicking noise?
There was an old TSB on this.. Malaysia Boleh!
Post #199520 Sat Dec 13 2008 7:43am
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
I have exactly this. When I lower the car to access height to enter multi storey car pak and then leave it in access height I notice the clicking from the front right wheel each time I turn left as I drive up into the car park. Am going to get it looked at next time its in.
Post #199522 Sat Dec 13 2008 7:51am
That's normal. 2005 Zambezi TDV6 - Gone but not forgotten
Post #199527 Sat Dec 13 2008 9:21am
Murdered out
wierd that you say that, you're good!
last night I did a thorough examination. When I put the vehicle in N, and rocked it back and forth I could hear the brake pad rubbing like it was just wasnt in place properly. The clicking noise is also comming from the caliper region.
It must be that, I'll have to take it in.
Is this something that any brake shop can fix? or does it take a special LR part?
Post #199583 Sat Dec 13 2008 7:32pm
Bobby
I'm not sure if this affects your newer vehicle cos that TSB was for older ones. Anyway, if I remember correctly, you have to get a 'Parking brake service kit' and also renew the parking brake shoes.
If you can get those parts then I figure any brake shop should be able to fix it.
Good luck! Malaysia Boleh!
Post #199601 Sat Dec 13 2008 10:32pm
Murdered out
that sucks, I've used my EPB maybe once or twice....
Post #199607 Sun Dec 14 2008 2:10am
Bobby
Its just a retaining clip.. could be dislodged or broken even if you use the EPB once.
Moreover, you still need to first confirm if this is the problem! Wink Malaysia Boleh!
Post #199608 Sun Dec 14 2008 3:12am
Murdered out
right, I'm just going to let the dealer figure it out.
Post #199609 Sun Dec 14 2008 3:17am
