Home > Technical > Phone compatibility
Page 1 of 5 12345>
Roland
Switzerland
Phone compatibility
Just a quick question. I can get a new Motorola V3 Bluetooth which uses the latest software version 42, which is newer than version 40.3CR (listed as being approved for that phone by LR).
Since version 42 is newer, my feeling is that it should work as well. Any ideas? SOMETIMES YOU'RE THE BUG AND SOMETIMES YOU'RE THE WINDSHIELD
2010 TDV8 Ultimate Edition, zermatt-ebony-grand lacquer, and all the goodies, plus Superchips Bluefin ECU performance upgrade, Gibson Performance exhaust tips
gone after only 7 months: MY10 TDV63.0 HSE, zermatt-ebony-anigree, Dynamic Response, Rear diff-lock, flappy paddles, premium leather, Sunroof, PTI, privacy glass, S/C design 5 Spoke Diamond Turned alloys
Post #19809 Wed Mar 22 2006 3:41pm
Hey - my new Nokia N70 isn't even listed at all ! BUT it works excellently 100% on bluetooth including all voice controls etc Thumbs Up
Post #19813 Wed Mar 22 2006 4:00pm
Roland - yes it should. 2005 Zambezi TDV6 - Gone but not forgotten
Post #19814 Wed Mar 22 2006 4:02pm
Mrs S has a Samsung which is not on the list.
Works fine on Bluetooth Very Happy Runner up - 2009 Best Avatar Award Sad
Post #19845 Wed Mar 22 2006 4:34pm
RAD
Scotland 2009 Range Rover Sport TDV8 HSE Stornoway Grey
I've used the Motorola V3 and now the V3i and they work perfectly with bluetooth. Obviously, you can't use the onboard address book, but everything else, including voice activation works just fine.
Post #19876 Wed Mar 22 2006 5:54pm
Roland
Switzerland
OK, many thanks. What would we all do without this forum. Laughing I'll now go and get that Motorola.
Hopefully there will also be a Motorola cradle available in the not too distant future. SOMETIMES YOU'RE THE BUG AND SOMETIMES YOU'RE THE WINDSHIELD
Post #19884 Wed Mar 22 2006 6:45pm
ddr10
United States 2006 Range Rover Sport Supercharged Java Black
RAD - when you refer to voice activation, are you referring to the RR voice act. or the mot phone voice recognition? 06 RRS SC - W O W !!! (Blk/Blk)
03 Discovery HSE (Blk/Blk)
93 Mazda RX7 (Blk/Red)
Post #19892 Wed Mar 22 2006 9:14pm
Think he's referring to the LR voice activation. RRS TDV6 Gone but still around
Post #19894 Wed Mar 22 2006 9:19pm
grommet
United States
99.9% chance there will never be a cradle for V3/RAZR. Look at the design of the phone. It doesn't even have a normal docking point, just a USB connector on the side. It was not designed to dock.
And yes, all "voice control" will be the PTI's own voice control.
Post #19900 Wed Mar 22 2006 10:10pm
RAD
It was the LR voice control.....the Motorola one isn't very good. But I must admit that I also use the LR keypad for entering numbers, works perfectly - obviously never on the move.
Post #20137 Thu Mar 23 2006 5:24pm
canaryman
Germany 2006 Range Rover Sport TDV6 SE Cairns Blue
I am a bit dim with technology so I would appreciate some guidance.
I have a Motorola V3X but cannot get the bluetooth to find the Landrover bluetooth in the car. I have tried everything but I just get a blank.
I remember something the salesman said that, in the car, it needed "activating" but nothing more than that.
Is there a way to "activate" bluetooth in the car or am I missing something. (I have read and followed the RRS instructions and my phone instructions but nothing)
Thanks for help
Smile
Post #20171 Thu Mar 23 2006 6:12pm
Did you try putting the phone on to find me mode and then getting the car to look for the phone Question RRS TDV6 Gone but still around
Post #20173 Thu Mar 23 2006 6:16pm
grommet
United States
Bluetooth is always on in the vehicle. You should be able to see a device called "LAND ROVER" on your phone.
Page 4 has Bluetooth instructions:
http://www.landrover.com/assets/gb/en/Vehi..._Guide.pdf
If this doesn't work, it's either your vehicle... or your phone. (So, test another phone... or try to use your phone in another Land Rover.)
Post #20174 Thu Mar 23 2006 6:16pm
canaryman
Ok. I have no phone buttons on the steering wheel. Is bluetooth standard on the SE? The salesguy said it had bluetooth but I have just tried again, following the instructions to the letter, yet again and no devices found.
When I press the button with a phone set on it (on the radio headset) the lcd display says "no phone fitted"..................confused??!! I am!!
Post #20179 Thu Mar 23 2006 6:29pm
I wouuld presune at you only get the buttons on the on steering wheel with PTI so you may not bluetooth if there not there. RRS TDV6 Gone but still around
Post #20181 Thu Mar 23 2006 6:38pm
Page 1 of 5 12345>
