Home > Technical > Phone compatibility |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 |
Hey - my new Nokia N70 isn't even listed at all ! BUT it works excellently 100% on bluetooth including all voice controls etc
Wed Mar 22 2006 3:00pm |
Roland - yes it should. 2005 Zambezi TDV6 - Gone but not forgotten
Wed Mar 22 2006 3:02pm |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 |
Mrs S has a Samsung which is not on the list.
Wed Mar 22 2006 3:34pm |
RAD Member Since: 23 Sep 2005 Location: In the chippy! Posts: 309 |
I've used the Motorola V3 and now the V3i and they work perfectly with bluetooth. Obviously, you can't use the onboard address book, but everything else, including voice activation works just fine. |
Wed Mar 22 2006 4:54pm |
Roland Member Since: 10 Jun 2005 Location: NB Posts: 469 |
OK, many thanks. What would we all do without this forum. I'll now go and get that Motorola. Hopefully there will also be a Motorola cradle available in the not too distant future. SOMETIMES YOU'RE THE BUG AND SOMETIMES YOU'RE THE WINDSHIELD 2010 TDV8 Ultimate Edition, zermatt-ebony-grand lacquer, and all the goodies, plus Superchips Bluefin ECU performance upgrade, Gibson Performance exhaust tips gone after only 7 months: MY10 TDV63.0 HSE, zermatt-ebony-anigree, Dynamic Response, Rear diff-lock, flappy paddles, premium leather, Sunroof, PTI, privacy glass, S/C design 5 Spoke Diamond Turned alloys |
Wed Mar 22 2006 5:45pm |
ddr10 Member Since: 10 Mar 2006 Location: VA - USA Posts: 11 |
RAD - when you refer to voice activation, are you referring to the RR voice act. or the mot phone voice recognition? 06 RRS SC - W O W !!! (Blk/Blk)
Wed Mar 22 2006 8:14pm |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
Think he's referring to the LR voice activation. RRS TDV6 Gone but still around
Wed Mar 22 2006 8:19pm |
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 |
99.9% chance there will never be a cradle for V3/RAZR. Look at the design of the phone. It doesn't even have a normal docking point, just a USB connector on the side. It was not designed to dock.
Wed Mar 22 2006 9:10pm |
It was the LR voice control.....the Motorola one isn't very good. But I must admit that I also use the LR keypad for entering numbers, works perfectly - obviously never on the move. |
Thu Mar 23 2006 4:24pm |
canaryman Member Since: 16 Feb 2006 Location: Haag a.d amper Posts: 188 |
I am a bit dim with technology so I would appreciate some guidance.
Thu Mar 23 2006 5:12pm |
Did you try putting the phone on to find me mode and then getting the car to look for the phone RRS TDV6 Gone but still around
Thu Mar 23 2006 5:16pm |
Bluetooth is always on in the vehicle. You should be able to see a device called "LAND ROVER" on your phone.
Ok. I have no phone buttons on the steering wheel. Is bluetooth standard on the SE? The salesguy said it had bluetooth but I have just tried again, following the instructions to the letter, yet again and no devices found.
Thu Mar 23 2006 5:29pm |
I wouuld presune at you only get the buttons on the on steering wheel with PTI so you may not bluetooth if there not there. RRS TDV6 Gone but still around
Thu Mar 23 2006 5:38pm |
