![]() | Home > Technical > smoke from preheater infornt of battery. |
RonnieG Member Since: 16 Mar 2008 Location: Armagh Posts: 207 ![]() ![]() ![]() |
Right I have had the software upgreade and thats fine, but now as Friday was the first day I had off I notice that there is a big pool od diesel where it has been running out of the pipe coupled to the fact that my milage has gone down by nearly 8mpg.. You can see where it is coming out of the pipe and has spattered right up the underside of the RR... any ideas?! please dont tell me this is normal because if it is gawd help us!! |
simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259 ![]() ![]() ![]() |
The fuel pump for these heaters has two speeds, Start and Run, sounds like yours is running too long at start rate or not ever dropping to the run rate, hence lots of smoke from the unburnt diesel and/or diesel running from the exhaust.... back to the dealer! Cheers Simon 2007 2.7HSE 20" Wheels 2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes |
Thanks Simon
glenn Member Since: 05 Nov 2008 Location: Hampshire Posts: 26 ![]() ![]() ![]() |
Hi just to say that I have just had the same problem as your rrs, The clouds of smoke from the front of the car on passenger side with a stronge smell of diesel. only had it two weeks now .so looks like it have to go back for a check over. Range Rover Sport HSE,Java Black,Allround Tint's, Black and silver badges,Black and silver wheel centers,Up graded leather,Brembo brakes,white side repeater lenses,led number plate bulbs,led side lights bulbs,led reverse lights bulbs, led interior bulbs,Front and Rear mud flaps. Looking for private number plate. black and silver front grill and side vents and replaced the boot strip with black one |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
Did you both get this one sorted out?
Spoke to lancasters at reading about it and they said it was normal for this time of year . To do with the cold weather , let's hope he's telling the truth |
Yea after about 2 weeks or so once it had cleared its self of old diesel and soot, mine is now running clear and on smells whatsoever. I did get the timimg reset as the motor was not changing over from start to run spped and also the software to block off the vents when it first starts so alls good now! thanks for the help. |
