![]() | Home > Maintenance & Modifications > CARPUTER /CARPC install from the USA |
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
wow - looks very neat indeed - I'm liking the keyboard gadget too |
Murdered out Member Since: 08 Feb 2008 Location: Arizona Posts: 324 ![]() ![]() ![]() |
Here's the plug and play version in case anyone is interested.
crowej Member Since: 21 Apr 2008 Location: Dublin Posts: 289 ![]() ![]() ![]() |
i am going to do this, couple it with this
Steve in germany Member Since: 15 Nov 2007 Location: Bad Lippspringe Germany Posts: 980 ![]() ![]() |
Thats a bit different than what he did. I'm not sure if thats the smartest way to go about that. Its like reinventing the wheel in completely different way. The best way and easiest way is just to purchase an actual carputer, whuch just plugs in and thats its. There's no messing around with soldering, circuitry, etc. Just re-route some RCA's and you're done. Is about a 1 hour install and they're turn key systems. They come loaded with all the software, hardware etc. ![]() |
yes but nice to be able to use the touch screen to control the carputer. i would do the usb/touch screen mod regardless |
you can use the touch screen, thats what the carputer is all about. Everything is pre-programed and is setup to work with touch screens exclusivley. The stuff Chrono posted is an eee PC not a carputer. The carputer is what you want to buy and they're only a few hundred dollars. |
xLusi0n Member Since: 12 Jun 2007 Location: Los Angeles Posts: 92 ![]() |
How'd you hook up the audio? From what I understand, the GNET doesn't do audio?
i think your wrong dude, the only way to get access to the touch screen control on the RRS is through the mod i mentioned earlier. |
i dont think he is using the gnet unit, the unit he has has a FM transmitter built into it . |
FAT_RRS Member Since: 18 Jun 2008 Location: COLORADO Posts: 98 ![]() ![]() ![]() |
He isn't using the GNET, he is using the newest and best Video on Nav module he bought from me. Yes, there is a built in FM modulator.
chronoguy Member Since: 11 Apr 2007 Location: San Francisco Posts: 9 ![]() ![]() ![]() |
Yep, I got it from FAT_RRS. The GVIF-07 (similar to GNET) has 3 AV inputs, RGB and Camera in and 1 AV Out. I am not using the FM Transmitter. It is behind the seat and I route the AV OUT to the AUX In on the back of the console. FAT_RRS has a great price and it was easy to hookup. The EEEPC has no heat issues that I am aware of. I have used it 2 hours at the most. There is no hard drive. It is SSD Solid State Drive. I will look into the touch screen hack. YOU TUBE VIDEO HERE: RRS CARPC http://www.youtube.com/watch?v=3ggK0f0xQ_g SD/MP4 Player http://www.youtube.com/watch?v=AvR-8oDAx_s |
aslostasyou Member Since: 30 Dec 2008 Location: Tampa, FL Posts: 1 ![]() ![]() |
Greetings.. What an amazing idea! Thank you to those who have put forth the effort to bring this to fruition. For someone lacking the technical skills and A/V understand can you possibly detail exactly what's needed going the eee PC route please?
Looks good - but I'm yet to be sold on the value of a carputer |
