![]() | Home > Maintenance & Modifications > Audio / Speaker / Amp upgrade in RRS HSE |
bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496 ![]() ![]() ![]() |
Ahh yes i never thaught of a Hi/Lo converter, does this type of conversion need a 12v feed and GNG.
Do you have any pictures and sizes of the standard sub and speakers ?
Thanks m8. I recon you will have a nice looking and sounding system when your done. Follow Us On Twitter @bellautos |
imgleb Member Since: 07 Apr 2008 Location: New York Posts: 3 ![]() ![]() ![]() |
Hey my question is --> how do u hook up a high low converter to the subwoofer wires? I thought they are supposed to be hooked up to speaker wires and the high low convrter then converts it. (maybe I am not understanding something). Is there a way to tap into the line level speaker wires (that are not amplified and are coming directly from the head unit before they reach the stock amp)
Murdered out Member Since: 08 Feb 2008 Location: Arizona Posts: 324 ![]() ![]() ![]() |
the wires that my high low converter were tapped into into are from the headunit, I'm not sure exactly on why things were done certain ways but this is the way that at least 5 other RRS owner hooked up thier systems.
Well due to the extreme power that is drawn from my battery and charging system due to the amp, my power system has gone down the drains causng my entire left side repeaters to fail completely. My parking sensors fart instead of beeping and my interior lights/cluster flashes like a disco everytime the bass hits.
Chauster Member Since: 13 May 2012 Location: Glasgow Posts: 13 ![]() ![]() ![]() |
Would using 1 farad or 2 farad capacitors not help ? |
Sag Member Since: 07 Jul 2009 Location: Leicester Posts: 564 ![]() ![]() ![]() |
This thread is 4 years old so he might have fixed his problem ![]() Either way, power caps are pointless. To run a high draw system the best thing to do is use a split charge battery system and upgrade the power cables to and from the alt. LCFC. Receiver of threatening letters from Overfinch. |
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 ![]() ![]() ![]() |
Yes this system was an amazing sound, my mate would not sell his for anything else!
