Home > Technical > Looks like my clutch is dying!
Page 2 of 3 <123>
BigMart
you have PM
Mart Jaguar XF 3.0D Portfolio
RRS TDV6 HSE 2006 , Zermatt , Gone
Post #196438 Sun Nov 16 2008 12:49pm
bellautos
United Kingdom 2005 Range Rover Sport TDV6 HSE Cairns Blue
Does this box have a filter, i cant seem to locate it on Microcat.
I must admit im not the best when it comes to gearbox components as i try and steer clear of the smelly oil if possibile lol.
Regards Pete
Post #196439 Sun Nov 16 2008 1:03pm
BigMart
Hello Pete,
I surfed around a few zf sites last night , the filter appears to be built into the sump pan....which is plastic by the way.. Shocked
look here..http://www.europeantransmissions.com/
about halfway down the middle of the page it says ..what you should know.
and here for the exploded views.
http://www.zf.com/na/content/media/import/...ilable.pdf
Make notes and take pics while you are doing it , Pete. You might have a few more to do..
Mart.
PS. Give us some details of your new RRS Jaguar XF 3.0D Portfolio
Post #196440 Sun Nov 16 2008 1:09pm
bellautos
Thanks for that mart, ive found the sump/filter on microcat, itlooks as tho it can come as a kit with the gasket and seals etc etc. This will make life easer.
http://www.bellautoservices.co.uk/TDV6-Autobox-Sump.jpg
Ill take some pics as i go on.
My new RRS is a Aug/2005 HSE 2.7 in cairns blue, with side steps mud flaps privacy glass etc etc.
ive just fitted to 20" SC wheels, and the SC grill and side vents and somoe black badges as you do Smile
Im looking into a Brembo SC brake upgrade as we speek, and then ill produce some Decat front pipes and possibile some full systems.
And of course my mapping with the BAS remap interface Smile
Ill post some pics later on.
Regards Pete
Post #196442 Sun Nov 16 2008 2:18pm
Nutty Nige
United Kingdom 2009 Range Rover Sport TDV6 HSE Stornoway Grey
Big Mart - you have a pm
regards
Nigel. You don't stop playing because you get old, You get old because you stop playing.
07 TDV6 been and gone. 08 TDV6 been and gone. 08.5 TDV8 in evaluation mode and now gone. BMW 535D M sport Been and gone, Now time for RRS No4 - TDV6 HSE in Stornaway with Ebony - 09 Model 6 months old.
RS Cosworth 4x4 Stage 2 Mint for summer
Audi TT
Astra VXR for the daughter.
Post #196444 Sun Nov 16 2008 3:15pm
Pelyma
Having no technical knowledge, but an enquiring mind; VA's car has done far less miles and far less off road (both in amount and difficulty) than many D3s; so why would that be a factor? We haven't seen any thing like this on the D3 site, despite older cars, although I suppose some are manuals. Porsche Cayenne S Diesel 66 Plate
Post #196448 Sun Nov 16 2008 6:19pm
BigMart
Driver abuse ?? Whistle Whistle
only joking
Post #196450 Sun Nov 16 2008 6:51pm
Thanks for all the advice everyone.
I will take the car in next to for LR to look at this. The car has only done 46k and very few of that offroad. I had the drive shaft (Think that's what went - can't remember 100%) replaced a few months ago which might be related. The problem could be a differential but I'm not a tech person so I wouldn't be able to tell you for sure. Fingers crossed that the bill will not be too high. 2005 Zambezi TDV6 - Gone but not forgotten
Post #196453 Sun Nov 16 2008 7:21pm
Nutty Nige
If it is clicking as well VA it might be the prop shaft spline spinning on the final drive unit. It is very common on Freelander and RR Vogue. Sounds more like that than the transmission. You don't stop playing because you get old, You get old because you stop playing.
Audi TT
Post #196457 Sun Nov 16 2008 7:29pm
highbridgeflyer
Given that LR have done a nation wide diff upgrade on the FFRR (from spline to flange) I would agree
Post #196464 Sun Nov 16 2008 7:49pm
PJPR01
United States 2006 Range Rover Sport 4.4 V8 HSE Cairns Blue
Are you sure that the transmission and drive train aren't still covered under warranty (not the standard 4/50 or equivalent in the UK, but the normally longer drive train warranty), and at any rate, the recommended change of filter and oil for the transmission is every 100k miles on the RRS, and the gearbox fluid is EXPENSIVE, so doing it every 20k is going to set you back a fair amount.
Judging by how much they quote to do it here, if it's double that in the UK, I doubt anyone would actually replace it before 100K.
From the maintenance schedules:
Change automatic transmission fluid and filter (10 years)
Change transfer gearbox oil (75k and 150k miles) ��
Change front and rear axle oil (10 years)
Change locking differential oil (75k and 150k miles PJPR
Cairns Blue HSE
180k Miles of Adventure
Post #196466 Sun Nov 16 2008 8:01pm
Nutty Nige
They did 2 mods Mart - a tool to line up the diff with porpshaft on front as the angle was seen to be wrong between the two, and then a build mod - but after the mod I had 2 fail with the same problem. You don't stop playing because you get old, You get old because you stop playing.
Audi TT
Post #196539 Mon Nov 17 2008 9:49am
Nutty Nige
What would you prefer is the obvious question - a transmission service every 2 years at £80 or a replacement transmission 6 months after warranty expires at a guess I would think around £4000 - £7000
It depends on application if you potter round all day chances are it will be fine.
If you get it stuck in the mud or tow a heavy obstacle behind when do you think - I will now stop for an hour to let the transmission fluid cool down due to the excessive pressure and heat I have just bestowed upom my car??
Your choice. You don't stop playing because you get old, You get old because you stop playing.
Audi TT
Post #196540 Mon Nov 17 2008 9:54am
bellautos
4 Ltrs of LRs Advanced ATF designed for the D3 and RRS autobox, £18.54+vat per ltr retail.
The pdf says 3.5-4Ltrs drain and refill.
Part Number TYK500050
Bottle says, specialy designed forauto trans on D3 and RRS.
Contains calcium sulphonate and alkyl amine.
I also asked the parts lad how much of this oil thy sell, his answer was ,They dont, they have only fitted gear boxes lol.
Regards Pete
Post #196549 Mon Nov 17 2008 11:16am
BigMart
Thats interesting Pete,
I looked at loads of oil websites yesterday to see what oils were on offer.
Most state the dexron rated stuff is not suitable and you must use that LR stuff which appears to be re-packaged shell m1375.4
You will need 4 litres but shouldnt we buy 8 litres because of the double flush? (160 quid Big Cry )
Any idea how much the trans sump pan is?
Post #196554 Mon Nov 17 2008 11:44am
Page 2 of 3 <123>
