![]() | Home > Maintenance & Modifications > Audio / Speaker / Amp upgrade in RRS HSE |
bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496 ![]() ![]() ![]() |
My head unit produces good sound eniough, but if you are after more you can possibily get some replacement standard fitment component speakers.
ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704 ![]() ![]() ![]() |
I really like the stereo in my tdv8. My last bmw had a full system and im not touching the rangey.
Jonathan Member Since: 11 Jan 2008 Location: York Posts: 434 ![]() ![]() ![]() |
Claws
I must admit im sure my wifes D3 has got a better subwoofer in the tailgate than my RRS, hers seems to have more boom as standard.
claws Member Since: 02 Nov 2008 Location: Bucks Posts: 7 ![]() ![]() |
Thanks all for your suggestions.
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
The factory Harmon Kardon for me is one of the biggest dissapointments, my Lexus had the Mark Levinson 16 speaker sound system and i have yet to hear any other system that was better, maybe LR should cut a deal and start to install the ML systems |
SILVER DOLLAR Member Since: 04 Nov 2008 Location: UK Posts: 44 ![]() ![]() |
Yes please post and let us know. I was wondering whether to leave the head unit and just upgrade the speakers. They sound so lame. The top end isn't crisp and the bottom end isn't tight. Not a good sound at all in my opinion. GUITARS AND CARS - YOU'RE EITHER IN OR YOU'RE OUT! |
bermyandy Member Since: 09 Sep 2007 Location: London Posts: 336 ![]() ![]() |
i will have a look today and confirm exactly what is in mine, but i recently dded a sub box, an amp and some other little gizmo
Murdered out Member Since: 08 Feb 2008 Location: Arizona Posts: 324 ![]() ![]() ![]() |
I jus add a 1000 watt JL amp and a JL 13W7 speaker 1500 w RMS. built a custom carbon fiber speaker box that fitsd behind the panels. I''m upgrading the component speaker's with Focal 6.5's 3 way speakers wwhich will linked to a JL HD 650w amp. my trunk is not finnished yet everything is being refinished with leather etc. no carpet. Its by far the loudest speaker setup I've ever had. This sub makes my windows flex ourwards when it is turned up to only 19. the 13w7 is the best sub you can buy, I had the TW5's by jl aka the thin ones, but they sucked... if you want real bass go with the W7 line
stretch felt to give shape,
Nice work. Follow Us On Twitter @bellautos |
ITCHY work! grinding, sanding and curring CF with pneumatic air tools is the itchiest I've ever been in my life. It was a long and hard process to do. The box is a beast though. its about 1/3 of an inch thick of solid CF. I added many layers but you cant tell in the pics. I also sound proofed my entire trunk arear with three layers of sound deadner. It sounds perfect, no rattles, and I also kept the stock radio. If I used a regular box, my tunk would be gone. That speaker requires 2.85 cubic feet for a sealed enclosure. by putting nearly the entire box behind the panels I saved my tunk space. |
Yes i can imagine it was very hard work ive made some enclosures in the past for some car projects i did and the hrs of labour that goes into a project like that is unreal.
yea that was my first box that i ever made. I gre up in Hawaii and surfed a lot, which is how i learned to work with fiberglass and carbon. I used a Hi/lo converter, and spiced it into the oem sub wires, so i can control the amp with the oem sub control on the stock radio. The hi/lo converter takes the regular wires an converts them into RCA's.
