Home > Tips & Tricks > Programmable Keyfob Button? |
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 |
Josh, yes they will. Just depends on the delay that you have set in the instrument panel.
Fri Nov 07 2008 11:01am |
DeletedUser2 Member Since: 06 Nov 2008 Location: Not a member Posts: 8 |
Wow, thought a car of that stature you would be able to do that. Never mind. What can the dealer program it to do? I guess change the seat configuration and the mirror setup when the key is put in? |
Fri Nov 07 2008 12:45pm |
You don't need your dealer to do that for you - a quick spot of RTFM will help you in that respect
Fri Nov 07 2008 2:42pm |
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 |
My son now thinks when I shout "navigation lights on " it puts the lights on MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Fri Nov 07 2008 8:32pm |
simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259 |
One thing to beware of is that if you set it to open the boot (ours is set to the full boot, donīt know about the glass but I suspect it is the same), you then CAN lock your keys in the car - which is normally quite difficult.
Fri Nov 07 2008 9:52pm |
I would say this is very good advice!! Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Sat Nov 08 2008 9:40am |
Simonsi
Sat Nov 08 2008 10:00am |
Money Money Money Member Since: 09 Feb 2009 Location: England Posts: 32 |
My Alarm goes off if I open the boot without opening the car??!! |
Mon Feb 09 2009 1:45pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
If you have a 2006, that problem could be fixed. On a number of MY06s, the Central Junction Box would expect the rear liftgate / boot to be physically opened within 400 milliseconds of releasing it with the remote button, if you took any longer (good luck with that!), the alarm would automatically reset and would be triggered when the boot was finally lifted. If your car has that issue, the dealer can install a software patch for the CJB that will increase such "authorized" opening time from 400 milliseconds to a more human 30 seconds. Since late production MY06s and newer, the alarm will reset 30 seconds after remotely releasing the boot as well. This is by design, to protect the car from unauthorized access if the button on the remote is pressed accidentally by the owner. |
Sun Feb 15 2009 4:04am |
R33 Member Since: 14 Jun 2008 Location: Marlow Posts: 193 |
Yay, finally got this working so I can have the follow me home lights on and not be plunged into darkness in the garage over and again, thanks James! |
Mon Mar 09 2009 2:29pm |
Another SW Member Since: 14 Mar 2009 Location: N Bucks Posts: 180 |
Did you guys know you can have the Land Rover button programmed to do different things with different keys?
Thu Mar 19 2009 9:58pm |
pjpocket Member Since: 10 Feb 2009 Location: Limassol Posts: 124 |
Yeah but it would make more sense if this option was available as a pre-getting-into-the-car option... I drive my parents around every now and them and my old man's got a bad back. The option to lower the suspension as we are about to get in (especially without the hazzards on) would be great. |
Fri Mar 20 2009 7:49am |
PJ, simple cure for this situation as I have a similar situation here...........................
Fri Mar 20 2009 8:59am |
Lol... Fair enough... I'm going to give it a try using the Keyfob Button just for curiosity's sake tonight but I still think the lights are the most useful out of the 5 options... |
Fri Mar 20 2009 10:21am |
