Home > Tips & Tricks > Programmable Keyfob Button?
R33
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
I heard somewhere that you can program the third button on the keyfob to do different things. Mine currently opens the rear tailgate glass.
A few questions:
1: Can it be programmed?
2: If so then how?
3: What can it do, i.e. what are all the options
I'd also heard you can adjust the suspension height via the keyfob under some circumstances, is this the case?
I tried searching for other threads on this but came up blank.
Post #192482 Mon Oct 20 2008 12:29pm
Lookers Park Royal
All in the manual but if you get stuck let me know. It can be set to:
1. Panic Alarm
2. Open upper tailgate.
3. Open full tailgate.
4. Activate Headlights. (IMO the most useful of the 5)
5. Raise and Lower Suspension.
Regards,
James Thumbs Up
Post #192484 Mon Oct 20 2008 12:39pm
MAW
IIRC it is as follows,
You hold the keyfob button when executing the function, i.e. open the full tailgate with 'button 3' depressed. Release and let go - press button 3 and the tailgate will open.
I think the list of things you can get it to do are limited.
I don't think you can lower suspension from it - something to do with hazard lights needing to be on.
Post #192485 Mon Oct 20 2008 12:41pm
MAW
Typing at the same time !! Laughing
(My car left yet James?)
Post #192486 Mon Oct 20 2008 12:42pm
Sexy Pauly
wow really?
i can program my keyfob to lower the suspension? that will look so cool outside a club! RR Sport supercharged 06
strut grills, strut 22" wheels, Full Kahn Kit
Brembo big brake kit, tinted front and rear lights
CLS 63 AMG Mercedes 2008, Cayenne Turbo S 2007, C32 AMG mercedes 2004, Vito Van 111CDI 2004
Post #192487 Mon Oct 20 2008 12:52pm
R33
Excellent thanks, yes I wanted to set it to turn the headlights on.
I will RTFM, first time for everthing. Actually the second time James, I read the manual before I jacked my car up last time............................... Laughing
Post #192490 Mon Oct 20 2008 12:55pm
Lookers Park Royal
Hmmm and look where that ended up! Embarassed (not your fault)
1. Lights - Hold the button then pull the indicator stalk to flash the lights.
2 & 3. Boot - Hold the button then open either the upper or lower boot.
4. Panic - Hold the button then press the hazzard light button.
5. Suspension - Hold the button then press the suspension button.
In all instances hold both buttons down at the same time, you should here a ping when it's set. It will activate the last stored feature when you set it...... i.e. If it's currently set to the boot and you then change it to the headlights then as you set it the boot will open, however it will only happen the once.
The suspension feature is slightly more complicated. Once you have assigned the button you will need to have the hazzard lights on (a safety feature), all apatures closed, then hold the LR button and at the same time press Lock to go up and unlock to go down (or other way around).
The headlight setting is by far the most useful IMO as you can set the headlamp delay to max and then press the button to switch them off when you get to the front door (depending on hol long your pathway is).
It is quite interesting to try them all out anyway.
James Thumbs Up
PS. We encourage all our customers to read the instruction manual!!!!
Post #192498 Mon Oct 20 2008 1:35pm
Lookers Park Royal
En-route....... I am reliably informed that the ETA should be as per the email Wink and you will recieve a coded text once the final way-point has been passed! Whistle
James Thumbs Up
Post #192499 Mon Oct 20 2008 1:37pm
Jonny Fresh
[quote="Charles Hurst Park Royal"]
How ridiculous! Why doesn'y it just set the hazard lights going as it lowers!
Post #192500 Mon Oct 20 2008 1:39pm
R33
Thanks James, very helpful, will give it a go tonight Thumbs Up Thumbs Up Thumbs Up
Will stop my wife telling me off for leaving the lights on in the garage every day!
Post #192501 Mon Oct 20 2008 1:42pm
Lookers Park Royal
I understand that it is a safety feature so that there is no way that you can accidentally change the suspension height. For instance, if you sat on the key in your pocket and it activated the suspension, then there could be all sorts of consiquences. I think the reasoning behind it is that you have to make a concious decision to activate the hazzards before it will work.
James Thumbs Up
Post #192502 Mon Oct 20 2008 1:47pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Crikey Shocked
I am going to have some fun playing tonight......read the manual and must have completely missed those options............. Laughing L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #192512 Mon Oct 20 2008 2:22pm
DeletedUser2
What about programming the mirrors to fold in once you lock the car? Is this a DIY thing or will the dealer need to do it?
Thanks!
Post #195089 Thu Nov 06 2008 9:21pm
Lookers Park Royal
Sadly it can't be done on the RRS.... Rolling Eyes
Post #195104 Thu Nov 06 2008 10:22pm
Josh
So having turned the lights on with the button, will they automatically turn off without pressing the button again Question TDV6 - gone
TDV8 - gone
Post #195144 Fri Nov 07 2008 10:15am
