Home > Technical > smoke from preheater infornt of battery.
RonnieG
the preheater infront of the battery and behind the passenger side headlamp is smoking badly and there is a strong smell of diesel can anybody help or know what the problem is..
many thanks
ronnie
Post #193290 Mon Oct 27 2008 9:05pm
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
Are you sure this is not just the exhausted gases now being visible due to a drop in ambient temperature?
On a cold day you should be able to see a plume of smoke under the car from the FBH. L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #193291 Mon Oct 27 2008 9:08pm
RonnieG
yep its comming from a small pipe on the rhs of the sump at the passinger side which goes right up to a small exhaust box and into this preheater .. Plus it covers the yard in smoke you would think it was on fire!
Post #193292 Mon Oct 27 2008 9:24pm
RRUK
Problem solved!
No need to panic, all perfectly normal. L319 D4 HSE
1982 Series 3 SWB
Post #193297 Mon Oct 27 2008 9:49pm
RonnieG
REALLY THAT MUCH SMOKE IS NORMAL!!!!!!!!
think 15 year old diesel taxi amount of smoke?
not questioning u but it is pretty bad and this is normal. how come it has never been like this before now?
Post #193299 Mon Oct 27 2008 9:55pm
maybe a 'you tube clip' so it can be compared Idea
Post #193300 Mon Oct 27 2008 10:02pm
RonnieG
it is belching out smoke just enough to cover the front of the RR!!
Post #193301 Mon Oct 27 2008 10:04pm
it seems a little OTT to me, possible a diesel/oil leak onto a hot exhaust
Sounds like a trip to the dealer to me, as the ones i have seen just get a wisp of smoke
Post #193304 Mon Oct 27 2008 10:12pm
Lookers Park Royal
They can smoke quite dramatically the first few times that are called upon as we head into winter. They work on a thermostat so it's possibly the first time it's cut in this year. If in doubt give it to your dealer for a cold start test.
It's difficult to say 'that's normal' without seeing it, but the first few times it functions can produce an alarming amount of smoke.
James Thumbs Up
Post #193313 Mon Oct 27 2008 11:15pm
RonnieG
James you are a star! Thumbs Up
I thought that it might be the reason, but was unsure. you should see some of our diggers on a Monday morning! I will give it a couple of days to calm down and if no better will get it checked out.
Will keep u posted and many thanks guys
Ronnie
Post #193315 Mon Oct 27 2008 11:49pm
MAW
My last RRS used to smoke quite dramatically - really more than you'd expect but all perfectly OK
Post #193320 Tue Oct 28 2008 6:50am
RonnieG
started her this morning and there was a faint plum of blue/grey smoke for a short while and then it sleared so all is ok many thanks.. I am heading to the north of Scotland today so was worried that there was a problem. didnt fancy having to take the Mondeo especially as they are prdicting snow!!!!!
Many thanks guys
Ronnie
Post #193332 Tue Oct 28 2008 9:28am
Good news Thumbs Up
Post #193358 Tue Oct 28 2008 10:52am
Glad it's nothing more sinister Thumbs Up
Tend to use our FBH quite a lot these days... Confused Laughing Runner up - 2009 Best Avatar Award Sad
Post #193383 Tue Oct 28 2008 11:48am
RonnieG you live on a very cold island that's ok Wink
Post #193388 Tue Oct 28 2008 12:13pm
