![]() | Home > Technical > smoke from preheater infornt of battery. |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
Are you sure this is not just the exhausted gases now being visible due to a drop in ambient temperature?
RonnieG Member Since: 16 Mar 2008 Location: Armagh Posts: 207 ![]() ![]() ![]() |
yep its comming from a small pipe on the rhs of the sump at the passinger side which goes right up to a small exhaust box and into this preheater .. Plus it covers the yard in smoke you would think it was on fire! |
Problem solved!
REALLY THAT MUCH SMOKE IS NORMAL!!!!!!!!
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
maybe a 'you tube clip' so it can be compared |
it is belching out smoke just enough to cover the front of the RR!! |
it seems a little OTT to me, possible a diesel/oil leak onto a hot exhaust
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 ![]() |
They can smoke quite dramatically the first few times that are called upon as we head into winter. They work on a thermostat so it's possibly the first time it's cut in this year. If in doubt give it to your dealer for a cold start test.
James you are a star! |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
My last RRS used to smoke quite dramatically - really more than you'd expect but all perfectly OK |
started her this morning and there was a faint plum of blue/grey smoke for a short while and then it sleared so all is ok many thanks.. I am heading to the north of Scotland today so was worried that there was a problem. didnt fancy having to take the Mondeo especially as they are prdicting snow!!!!!
Good news |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 ![]() ![]() |
Glad it's nothing more sinister |
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 ![]() ![]() |
RonnieG you live on a very cold island that's ok |
