![]() | Home > Technical > Blackberry & The RRS |
gazza500 Member Since: 01 Aug 2007 Location: Channel islands Posts: 176 ![]() ![]() ![]() |
I am trying to transfer my BB Curve (latest software update) address book to the RRS over Bluetooth and am getting the message 'Object Push Server not found'
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
You shouldn't have to initiate the phonebook transfer from the BlackBerry, if the system works as intended the phonebook download should happen automatically every time the handset pairs with the car module. Make sure "Address Book Transfer" in the Curve's Bluetooth Options menu is enabled, other than that I don't think there is much you can do from the phone to make it happen. If you don't have a MY08, you will need the software "patch" downloaded into your car's Nokia module, and like the above poster said, there is a 50/50 chance phonebook xfer will work after that. |
Bodster2 Member Since: 09 Aug 2008 Location: Lisbon Posts: 102 ![]() ![]() ![]() |
I've got the same problem with my Blackberry Curve and RRS 07. Where can you download the patch from? Is it available from the internet or do I have to go to a Land Rover Dealer? Thanks |
Land Rover dealer must do it via IDS - for a fee, of course (although some got it done @ N/C), the upload takes about an hour of labor according to the bulletin. |
Thanks for the info umbertob... |
