Home > Technical > Random 'faults'
MAW
Random 'faults'
I have noted a couple of random events recently, i thought they would be 'one off's' and unable to reproduce. I had a second occurance of one of them yesterday,
1. Driving along, wipers would not function at all (front) on any setting, stopped in traffic, powered down, up - still the same. Powered down, locked and unlocked, wipers back on ONLY after selecting the immediate wipe (down) on the command stick.
2. Keys in the ignition, you wind the keys forward but no response (as if car is in drive) - ignition lights come on. Try again and it fires.... This I have repeated,
anyone had / seen similar?
Confused
I need to establish a confirmed fault if you like before reporting direct to James (who I know will get it sorted !)
Post #190412 Thu Oct 02 2008 7:16am
Sorry MAW, not experienced any of these faults.
Do sound like genuine electrical gremlins Runner up - 2009 Best Avatar Award Sad
Post #190413 Thu Oct 02 2008 7:22am
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
You are correct MAW, From my experience at the local dealer today unless a fault is logged in the computer for them to download they look at you as if the fault can't have happened!
Post #190414 Thu Oct 02 2008 7:22am
flydive
Re: Random 'faults'
I had this at the beginning with my TDV6, usually happened at the 2nd or 3rd start of the day. No fault found.
I got used to try to turn the key and wait for the car to go through the initial check then start. Don't know if it helped but never happened again for over a year. '08 RRS TDV8
Post #190421 Thu Oct 02 2008 8:07am
MAW
Thanks all - the ignition bug is as if the car doesn't recognise the key - like I imagine an imobilser would work...
Will continue to track Confused
Post #190425 Thu Oct 02 2008 8:41am
Lookers Park Royal
Embarassed
Sounds like it could be transponder related Question I had this before due to a flat spare key, however the car I tried to start was open, and I would guess that you unlocked yours so this will probably not be the case.
Embarassed
Keep me posted, we will not be beaten, however sometimes 'needle and haystack' springs to mind when the vehicle hasn't stored a fault.
Embarassed
Post #190433 Thu Oct 02 2008 9:06am
MAW
Thumbs Up Smile
I know you'll address James and I was only posting here to share the info and solicit feedback should it enable me to better report the problems.
I know it is like a PC on wheels and Bill Gates always gets the blame for the spurious unrepeatable faults !!
Laughing
Post #190454 Thu Oct 02 2008 10:33am
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
MAW wrote:
Thumbs Up Smile
Laughing
Bill Gates Censored that says it all, only he could invent a program that needs you to press start to shutdown Rolling with laughter Rolling with laughter
Post #190517 Thu Oct 02 2008 5:03pm
