Home > Technical > Hub Centric or Lug Centric?
xLusi0n
Are the Stormer wheels on a RRS lug centric or hub centric?
Post #189858 Sun Sep 28 2008 5:54am
Smarticus
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
..just when you thought you knew pretty much everything ... along comes a question like this and you realise that there is still a HUGE amount yet to learn. Aren't all wheels centric around their centre ?
One google search later and I find I know answer !
I am pretty sure that they are Lug Centred, meaning its a difficult balancing act to fit them as the only thing holding them in place are the lugs themselves, there is no central locating set up. I think this is true of all wheels on the RRS as the hub isn't shaped to hold a wheel itself. RRS TDv8 HSE Rimini
Disco 4 TDv6 HSE Ipanema
Defender 90, 200tdi CSW
Post #189868 Sun Sep 28 2008 7:16am
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
Although I don't own a set, I'd be surprised if the 20" OEM wheels - whether standard issue or Stormers - were not hub centric. The Sport being so sensitive to vibrations with less than perfectly balanced wheels, it would be strange for LR to supply lug centric rims, regardless of wheel style. Both my original 19" 5-spokers and 18" rims I use for off-roading are hub centric (makes sense since the 18s came off a Disco/LR3 and the hubs are the same as the Sport's.) My aftermarket Cargraphic are not, but the manufacturer provided aluminum centering rings to "make" them hub centric... Not sure about 22" Stormer replicas, but I would almost be willing to bet that the OEM Stormer wheels are hub centric.
Post #189879 Sun Sep 28 2008 9:39am
Smarticus
Sounds like I was talking " Censored ". Wouldn't be the first time - sorry .... RRS TDv8 HSE Rimini
Post #189927 Sun Sep 28 2008 8:06pm
