![]() | Home > Technical > Problem with RSS towbar |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
nope never heard that.. Use mine with no probs at all. |
He's just jealous!! |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
I put mine on once and it came away in my hand where the latch hadn't deployed but that was poss my fault - once that latch has locked I cannot see it going anywhere but with the RRS
The problem I have encountered isn't the towhook dropping out but the exact opposite - just occasionally it will not release when I want to remove it, I have had this happen with both RRs's I've owned. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
A thump on the side releases that I have found - rubber hammer or lump of wood. |
Yup, I've used that method too MAW, also a occasional squirt of aerosol spray 3-in-one oil helps keep the lock mechanism free - DON'T use WD40 though as it evaporates too quickly to be any good as a lube. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259 ![]() ![]() ![]() |
Once latched and locked fully it wonīt go anywhere, but sometimes mine needs a tap upwards with a mallet to fully seat, latch and lock so there is no red visible.
Japseroony Member Since: 06 Feb 2008 Location: At home with a beer!!! Posts: 256 ![]() ![]() ![]() |
Not had the problem of it dropping out but the f |
Tony H Member Since: 06 Sep 2008 Location: Doncaster Posts: 3 ![]() ![]() |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
no problems to date, it gets used twice a month for the bike carrier.. Another Pommie Bar Steward down under
