![]() | Home > General > leak and funny vibration |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
I may be able to help - I had a windscreen replaced but they damaged one of the trims (outside) I had a similar symptom and i surmised that it was due to the trim allowing water into the A pillar and finding its way down to the floor mat - when the new trim was fitted problem solved.
Firstly, I thought this would be down the one of the aircon drain pipes coming free and depositing water back into the footwell (this has been reported on a number of occasions) - but as it happens after a wash, logic says it must to do with seal somewhere.... windscreen's a good place to start - I take it you've looked inside the car to see if you can determine where the water seems to come from?
Could it be this...?
Another gold for Bobby! |
That was it ! |
trinrr Member Since: 18 Jul 2008 Location: West Indies Posts: 4 ![]() ![]() |
thanks for the help. will try the fix. As for the vibration. I agree that it is only momentary but it is rather dramatic and car is in normal mode when it happens. Feels like driving on a warped tire.Must admit to being very pleased with feedback. |
