Home > General > leak and funny vibration
trinrr
2006 Range Rover Sport 4.4 V8 HSE Java Black
Two questions.
Any advice on a leak which causes water, albeit minimal, to be deposited after a wash on the front passenger side towards the front of the floor mat?
Also on two occassions some time apart I have turned a corner slowly and felt a vibration, almost like driving with a warped front wheel. I stopped and then proceeded to drive again and there was no further vibration?
Look forward to responses
Sad
Post #184550 Thu Aug 21 2008 11:41pm
MAW
I may be able to help - I had a windscreen replaced but they damaged one of the trims (outside) I had a similar symptom and i surmised that it was due to the trim allowing water into the A pillar and finding its way down to the floor mat - when the new trim was fitted problem solved.
On the vibration what mode are you in access or higher?
Post #184558 Fri Aug 22 2008 7:00am
Firstly, I thought this would be down the one of the aircon drain pipes coming free and depositing water back into the footwell (this has been reported on a number of occasions) - but as it happens after a wash, logic says it must to do with seal somewhere.... windscreen's a good place to start - I take it you've looked inside the car to see if you can determine where the water seems to come from?
I wouldn't be worrying too much about the vibration if it happens momentarily just yet... Very Happy
Post #184561 Fri Aug 22 2008 7:09am
Bobby
Could it be this...?
http://www.rrsport.co.uk/gallery/albums/us...illar2.pdf Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #184573 Fri Aug 22 2008 7:39am
Another gold for Bobby! Bow down Thumbs Up
Post #184574 Fri Aug 22 2008 7:41am
MAW
That was it !
Post #184575 Fri Aug 22 2008 7:43am
trinrr
thanks for the help. will try the fix. As for the vibration. I agree that it is only momentary but it is rather dramatic and car is in normal mode when it happens. Feels like driving on a warped tire.Must admit to being very pleased with feedback.
Post #184735 Fri Aug 22 2008 8:34pm
