Home > General > I-pod for Range rover sport
nshort10
Hi there. I just have a quick question. Im looking at buying a hst range rover sport for next year. the question is can you get an ipod connector for the Sport so it plays through the head unit?
any help would be great.
Nicky
Post #181718 Thu Aug 07 2008 9:46pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Re: I-pod for Range rover sport
Nicky
1 - Good choice when you take the plunge, HST rules Thumbs Up
2. Yes to the IPod. You can either use the aux plug (which is the cheapest) and plug into your Pod
or
2a. You can get LR or a.n.other to fit the rebranded Dension unit to your RRS which sits wherever you want. Mine is in the glovebox - which TBH was a ridiculous idea, as I have no idea what track is playing Thud
The permanent kit does not allow you to see the playlist etc on the head unit, but it allows control from the steering wheel buttons. Barely a solution, but it works!!
We will not see FULL integration until the revised 2010 interior is launched. Big Cry
Hope that helps. L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #181723 Thu Aug 07 2008 10:02pm
nshort10
thanks very much for getting back to me so quickly.
I have a full alpine multi medi set up in my bmw atm, and i am used to the way the ipod works. eg. can pick my playlist, see what playing, change song/volume on steering wheel.
That a bit of a gutter. my old man got a m5 and when ever i use his i just use the aux and keep forgetting to turn it up and selecting a song is a pain.
Hw are the unit you use in yours?
if you dont mind me asking how much was it?
nicky
Post #181725 Thu Aug 07 2008 10:24pm
RRS - top marks on wading depth - bottom of class in ICE Whistle
Post #181728 Thu Aug 07 2008 11:20pm
AustenRRSSC
Scotland 2005 Range Rover Sport Supercharged Java Black
Harman Kardonn do a IPOD docking station, it hard wires into the aux line and has a docking station, which can be fixed anywhere, it also has a 2" screen that also can be fixed anywhere. The screen has the same display as your IPOD etc. It also comes with a small dial that you use to select which song etc you want to listen too!!
The local ICE specialist in Aberdeen was quoting around £250 plus an hours fitting.
Post #182196 Mon Aug 11 2008 9:49am
Now............. if you all had an Audi with the MMI ... you get FULL ipod connectivity - it's like having a built in ipod Whistle
Post #182267 Mon Aug 11 2008 11:54am
Pelyma
But what is it JC calls them? Confused Ah yes I seem to recall Whistle Porsche Cayenne S Diesel 66 Plate
Post #182351 Mon Aug 11 2008 3:51pm
JGreg1
United States 2006 Range Rover Sport Supercharged Java Black
Ok, dumb question, but I'll ask anyway. If I have my iPod plugged into the aux input, and then turn off the iPod when I turn the car off and leave it plugged in, will it draw any power from the vehicle’s battery? I would assume not, since it doesn’t charge through the aux input, but just want to make sure.
Post #182991 Wed Aug 13 2008 11:44pm
will_wonka
No power drain whatsoever Thumbs Up L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Post #182992 Wed Aug 13 2008 11:51pm
JGreg1
Thanks Will!
Post #183094 Thu Aug 14 2008 1:07pm
