Home > General > Right or wrong tyres? |
You should have had 55's before - 55's are what you need. 2005 Zambezi TDV6 - Gone but not forgotten
Fri Aug 01 2008 7:38pm |
EX-X5! Member Since: 24 Sep 2007 Location: Midlands Posts: 237 |
Could be wrong here, but I always thought that the profile (depth) of the tyre is reduced generally speaking as you go up in rim size to ensure the rolling circumference is the same - this means the speedo wont be out? Is this right? |
Sat Aug 02 2008 6:55am |
Michael997 Member Since: 31 Jan 2006 Location: Worcestershire Posts: 225 |
Thanks Guy's
Sat Aug 02 2008 7:00am |
Well ive got 20" stormers on - I think they are 45 or 50's - not sure and i'm not going outside to check cos it's raining |
Sat Aug 02 2008 7:09am |
Wimp Michael
Sat Aug 02 2008 8:15am |
My tyres are 255/55 19 - I was presuming you are on 19's from the picture on your avatar. 2005 Zambezi TDV6 - Gone but not forgotten
Sat Aug 02 2008 9:33am |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 |
Standard size on RRS 20" are 275/40R 20.
Sat Aug 02 2008 10:22am |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 |
The standard size is 255/50/19, however, 255/55/19 is perfectly ok. The G4 RRS have Goodyear MTRs that come in 255/55/19 so LR see nothing wrong with it. In fact, you'll have a smoother ride. |
Sat Aug 02 2008 1:46pm |
Thanks Guy's
Sun Aug 03 2008 6:31am |
Olduser2 Member Since: 02 Mar 2008 Location: Old User Posts: 115 |
My understanding is that you took off tyres which have a higher speed rating than your replacements (i.e you took off Y Rated = 186mph and replaced with V Rated = 149mph. |
Sun Aug 03 2008 6:51am |
Thats right Tumshie
Sun Aug 03 2008 7:17am |
John @ DW Member Since: 07 May 2008 Location: Wirral Posts: 105 |
The profile number is the height of the side wall as a percentage of the width so the 255/55/19 will be bigger than the 255/50/19. By running a larger diameter tyre you will put your speedo out, acutally your speedo will be 3.5% out so when your speedo reads 60mph you will actually be doing 62.1mph. Apart from that running the 255/55/19 should not be a problem. Your new tyres have a higher load rating, so you are ok there and tumshie is right about the speed rating so you will be safe to 149mph. www.designerwheels.co.uk
Mon Aug 04 2008 8:19pm |
